Hi there !!
I was checking som race photos from last summer and notice that Im mooving my feet alot when I bike , my heal is far up.
check out my right fot !!
is there any advantages or disadvantages to pedal like this ??
cheers !!!
Hi there !!
cheers !!!
Like your running gait or your swim form, your pedalling stroke will be somewhat unique to you. There is a range that is good and within which people will function optimally.
Hard to tell from a fixed picture, but your form does look good. Seat perhaps a slightly high.
I always fiddle around with this sort of thing in the winter/off season while on the indoor trainer - making minor modifications to my fit to see if a can get more comfortable or apply more power.
Fleck
Your seat is way too high, hence the heel up pedaling style.
I’m just a layman, but i agree that your seat looks high. Your far leg looks like it’s pretty extended, and it’s not at the bottom of your stroke yet. I would think that having to pull up with your heel and then get your foot back at a good angle to push down on the front side of your stoke would fatigue some of the smaller stabilizing muscles prematurely, instead of taking advantage of the large muscles. However, as I said, I’m just a layman.
Dig out some “Tour” videos, heels are way up. At least that’s what I remember noticing. Correct me …
thanks !!
ok , I will adjust my seat hight , an also check som giro/tdf TT videos.
will do some tests on my indoor trainer & see what happend with the power-output after the adjustments… hey… thats what januari & february is good for… isnt it !!!
Immediate changes of power, either better or worse numbers, doesn’t mean the new position is better. Your seat is so high that it is possible to see your hips tilted to the left from that photo which is side-on.
Your right foot looks high, but no higher than many riders,and in this static picture looks like part of the ‘ankling’ process. More importantly the left leg isn’t overly straight, neither is the left heel overly high. It is important to remember that pedal stroke is very individual, Coppi had a high heel on his ‘bottom’ foot, whereas Merckx had his heel down at a point within his stroke, and both were arguably better riders than most on this forum.
If your hips are rocking then the saddle is possibly high.
Undies
I should have been more specific: it seems to me, from watching pro roadies, that heels are up at the top of the stroke. The bottom of the stroke should be more like you trying to wipe some sh$@#$%t off your sole, as I read somewhere ![]()
