Favorite jacket for running in the rain?
I’m looking for a good lightweight jacket to run in. Would like it to be resonably priced and hopefully not too baggy so I could ride in it occasionally. Any ideas?
Come on, I know with all the OCD people on this forum, some of you have a favorite jacket!
Both Biemme & Northwave have an amazing rain jacket that actually breaths. I looks & feels weird, almost like skin…
I
I found this really lightweight jacket by Hind on Ebay for $5 but I don’t run in the rain unless I’m being chased.
jaretj
The problem with running jackets and rain is, unless it’s super cold, if the thing is at all water resistant you’re going to get just as wet inside it from sweat as you would from the rain - breathable, waterproof fabric is to some extent a fantasy when you’re working hard. So for me the key is to regulate temperature, not necessarily try to stay truly dry. If you seal yourself in, then start to overheat, then take the jacket off when you’re already wet and it’s chilly out, then you’re going to get cold.
I’ve got a Marmot Precip that has pit zips and a back vent, it’s pretty good for the price - there are lots of similar jackets out there. Since you’re concerned about fit, you’re going to be better off trying different brands and models on than just buying something someone else likes. Unfortunately there’s usually not much of a selection at a given store, even REI may only have a few suitable jackets.
Depending on what kind of temperature you’re dealing with when it rains, consider more breathable fabrics and layers, maybe a close fitting breathable soft shell that will still keep the rain from drilling you, but will let the heat out - as might be worn by a cross country skier. Alternatively, accept that you’re going to get wet and wear a couple of thinner technical fabric layers that won’t chafe or get heavy/soggy and use gloves/hat to regulate temperature. If your arms are covered with something that breaths and won’t hold water, then you can wear a vest (cycling vest or similar) to keep your core warm while still letting a lot of heat out from your armpits, and possibly out the mesh back. In fact the more I think about it, a vest and technical longsleeve top is usually what I wear in light rain (not that it rains all that much around here).
If it’s hailing or pouring down ice cold rain, then, sure, you’ll want a more substantial top, then go for something like the Precip or the REI Ultralight or maybe one of the Pearl Izumi bike jackets since you said you want to be able to ride in it too and those are cut for cycling (but still fine for running in bad weather).
read some interesting reviews about this jacket
http://www.golite.com/products/NS_proddetail.asp?number=AM1732
That said I’m with the previous guy, for running, any shell is fine. I rarely run in downpours (don’t need blisters) and for light rain, any breathable shell is good.
For the bike, I like my gore-tex shell I got from mec.ca
You describe my dillemma exactly. What prompted my question was the recent weather here in TN. I’ve gone for 3 runs this week in mid to low 40’s and rain. Not drizzle for the most part rain. As long as I’m out for 4 miles or less, a light jacket that gets totally soaked through is ok. If I want to run anything more though, that just aint enough. So I figured that ST has all answers to these questions.
I have a pair of precip pants and looked at the jacket but it looks too parka-like to be a good running jacket. It sounds like you run in yours but only if it’s really bad, or are you just speculating? For some reason, in my fairly extensive search of the internets, I didn’t even think about REI, I need to check there as well.
I do run in it, as you said if it’s really bad - dumping rain and cool enough to not immediately overheat. The pit zips do help. 40’s and rain would be pretty rare around here though unless we go into the mountains. When it’s full-on raining I tend to just enjoy being out there and probably don’t run as hard, so, still sweating but not so much that it’s miserable inside the jacket - also, with a cap on, I can sometimes unzip the front a bit unless it’s a driving headwind. As far as parka-like, yeah…it’s not heavy but it is a bit noisy and bulky in appearance - which is more noticeable the milder the conditions are.
I think you’ve probably got a lot more weather to deal with in general. The longsleeve top/windproof-waterproof vest/cap/gloves might be worth a try for you, but I guess that might not be quite warm enough…maybe it depends on which particular shirt and vest. Or, move out here to So Cal :slight_smile: If it was colder here or I went up high more often in the “winter”, I might try something like the Asics Storm Shelter (google it).
Sounds to me like you need an additional layer of some technical fabric instead of something waterproof. You will either get wet from the inside or outside. Dress so you can be comfortable while wet.
I love running in the rain…the more it poors, the better. I have a wind shell that I will run in if it is cold, but I don’t expect that to keep me dry, it is just to block the wind. That and a hat with a brim to keep the rain out of my eyes.
Victor
Living in the NW you learn to enjoy running in the rain, or you don’t run much for 8 months out of the year. If it’s cold and raining I might wear my craft vest, but for the most part I just accept that I’m going to be soaked.
The first mile is usually miserable, but once I’m wet and get in a groove I really don’t mind it.
scott
Gore Bike N2S (Next to skin). Get the one with the zip-off sleeves. Perfect.
The best rain jacket I’ve ever owned… : Patagonia - Spray Master
