Need some recommendation for base bar extensions in order to have a higher hand position.
I have a P5-6 with the Aduro bar, and I recently had riser cuts so the pads are now at a 10deg up angle. Problem is now I can’t grab my extensions. So far the highest rise I have found for an extension is the Zipp vuka alumina evo with a 110mm rise. Is there any other out there somebody would recommend?
I’ve got 30 degree Use Tulas fitted backwards. Placing the angle closer to the extension clamps means more rise by the time you get to the end of the bars.
Pictures better than words. Had to drill a couple new holes for cable entry but no biggie.
I really liked the HED lazy-s extensions. I had my clip on bars on my Transion angled up 10 degrees and I could tuck in quite well. I think my profile picture is of that bike, so you can check it out.
Drag2Zero makes some very nice extensions in different angles, but they are quite pricey.
Thanks!
Zipp makes the Evos in carbon now too and Mat Steinmetz’s 51Speedshop is offering similar carbon extensions soon.
Thank you all for the ideas! I will check them all. My most pressing issue at this point is to get them ASAP. Seems like a “out of stock” is not uncommon at this point of the season for many manufacturers.
