My roommate’s cats peed in a suitcase full of clothes in my room.
How do you get the smell out?
OMG it stinks. Will it ever get out of my clothes? I tried some kind of Oxy spray on the carpet and well, I still want to vomit.
The product that we use is Odo-ban. Comes highly concentrated, so that you can dilute to the strength level that you need.
Available at most pet or hardware stores.
You need, first and foremost, before you do ANYTHING else, a urine neutralizer. You’ve already put some cleaner on it, so it may not be as effective, but run to PetSmart or wherever and get some Nature’s Miracle (preferably the Just For Cats version, although the other stuff will work) http://www.drsfostersmith.com/Product/Prod_Display.cfm?pcatid=3526&N=2002+113638 . It will neutralize the odor–i.e. get rid of the stink AND make it so the cat can’t smell it and want to try it again.
Soak the clothes in it, then wash as normal. For the suitcase, I’d get the spray bottle, COMPLETELY saturate all affected areas of it, and let it air dry somewhere. You may have to repeat the process.
As the owner of two dogs and three cats (one with a “sensitive” bladder), I SWEAR by this stuff. We literally do buy it by the gallon. And it’s good for most biologically-based stains…not just urine.
Yeah so you might want to try some uhhhhhh ummmmm uhhhhhhhhh wellllllllllllllll…“Anti Icky Poo” cough
Try and use a wet vac / carpet spot vacuum , soak it with water " extract as much as you can " .If you don’t get to the bottom of the smell it will never go away ( like carpets when its in the padding ). Now use the natural pet deodorizer stuff . Cats love to pee in suit cases
Pee on the cat, that’ll teach the little furry swine!
wash the clothes and spray some fabreeze in the suitcase
Burn it all. It’s ruined
