Ergvideo Questions
Was hoping some of you could help with a few questions, as I am anxious to buy these to get a program going for myself…
I did PM Paul S these questions, but haven’t heard back.
  1. During one of the youtube walk-thru videos, it says that multi-rider mode is preferred. …When you use ‘multirider’, are you referring to the fact that there are physically two of you hooked up to trainers and the same computer?? Or is this something you do over the internet with another computrainer owner?? Otherwise why choose this mode?
  2. What happens if I buy a new computer? Can I activate the videos on the new computer if they had already been activated on an older computer?? No, I’m not intending to sell or give copies to my friends. I replace my laptop every so often, so this is a concern to me.
  3. Which pack should I buy??? I want to be able to use them to make up a good 3 - 4 month training program. I see there are the 9 disc packs to use with their online training program generator. Then there are the Hunter Allen packs, the Richard Wharton packs, etc…which should I get?!
Thanks!
Paul will likely get back to you soon as he is generally very responsive, but here’s my views.
  1. MultiRider refers to the program from Racermate as opposed to their Coaching Software that comes with the unit. Both of these allow you to ride in erg mode versus the 3D course mode. The advantage to using the multirider software is that it allows you to change the wattage while doing the ergvideo which is nice if you’re like me and want to push hard sometimes but then discover 45 minutes in that maybe that wasn’t a good idea and you need to back off the wattage a bit. It allows you to hit the controller and lower the wattage a watt at a time. In the Coaching software you cannot change it. And multirider can be used by 1 or more riders so it doesn’t necessitate more than 1 rider.
  2. You need to get a code to do this and I have never had to do s. You need to check with Paul on this one.
  3. The base pack is a good starting point. The tempo group ride is a spirited tempo ride that makes it enjoyable. I’d get these videos and then build from there. If you are like me you will discover that it makes the Computrainer hours go by much better. If you have had a long rough day at work and want to ride but need motivation, the ergvideo’s do the trick.
support -at- ergvideo -dot- com
ST is not my inbox, thank you.
Paul
Paul
Sorry…
