Ergomo upload to Training Peaks
I have used Training Peaks for a while w/o any problems, and have uploaded files from my CT w/o incident. I just got an Ergomo and uploaded the data to Ergoracer on my PC no sweat. When I went to Training Peaks and tried to upload the WKO file, I keep getting the following message:
Microsoft VBScript runtime error ‘800a003e’
Input past end of file
/map/cpsoftuploadreader.asp, line 205
This is the first time I have tried to upload the Ergomo data? Any ideas what the problem is? Do I need to be a subscriber to Cycling Peaks as well as TP? I thought TP would be enough.
Thanks.
I was in the same situation. There is no need to buy cyclingpeaks because ergoracer (the program that came with your ergomo) is the same program. What I did to fix it was upload the file directly from ErgoRacer. Make sure that you are running the latest version of the software (2.0) and your password is all lower case with no special characters. The all lowercase is a known bug with the program and is suppose to be fixed in future updates. It was a frustrating process but once I figured out the nuance’s of the two programs I have had no problems. Hope this helps.
“What I did to fix it was upload the file directly from ErgoRacer. Make sure that you are running the latest version of the software (2.0) and your password is all lower case with no special characters.”
When you say upload directly from Ergoracer, do you mean select “ergomo/cycling peaks” in the upload drop down menu of the add workout section of Training Peaks or is there another way to get the file? That’s what I did that resulted in the error message.
Also, when you refer to my password, are you referring to the TP password? if so, that was input using lower case letters.
Thanks for your input. This process is very frustrating.
Hey GIO,
Not sure exactly what the issue is, but feel free to send me the file by email and I will take a look: gear at-sign trainingpeaks dot com
Also, you can take a look at this page for the direct upload: http://www.trainingpeaks.com/cyclingpeakspr1.asp
Feel free to contact our support folks in the future too: http://www.trainingpeaks.com/support
cheerz,
Gear
TrainingPeaks Co-Founder, CTO
How would you go from Ergoracer 1.5 to Ergoracer 2.0? - E
**When you say upload ****directly from Ergoracer, do you mean select “ergomo/cycling peaks” in the upload drop down menu of the add workout section of Training Peaks or is there another way to get the file? That’s what I did that resulted in the error message. **
Sorry for the confusion. What I was referring to was U/L directly from the program ergoracer. I am doing this from my computer at work so it may be a little off… Select and open the appropriate workout from your calendar, go to file and select upload to training peaks. As long as you have selected the ability to U/L to trainingpeaks from the main page and your password is all lowercase you should be golden. Hopefully this helps out, let me know if you have any more questions.
Okay, now I got you. Will try it tonight. Thanks.
