Ergomo crank choices?
I am going to go with an Ergomo PM. But - I have DA 10, which I can’t use. What is the best route to go…
  1. Another brand 10 speed crank & BB? (I’m not a fan of FSA - convince me otherwise)
  2. Go with a DA 9 speed crankset?
  3. Other options?
-Mac
If I remember correctly, the Ergomo is only available in the square taper style bb, so a 9-speed DA would not work. You’d have to go to an 8-speed DA crank for that.
I’m using it with the Zipp square-taper crank. Very nice. I’ve heard the Ergomo crank is also good.
-C
You can use any square taper, octalink or isis drive system.
I use Ergomo, ISIS on 2 bikes. Both have FSA cranks and work very well.
Take a look into Stronglight. I got two of their cranks on my Ergomo. Very very nice.
Suggestions?
I used FSA without problems. A bit pricey but I think the new zipp cranks would work, but for the money the Ergomo cranks seem like a good deal.
Does the DA 9 speed use Octalink? Which I believe works with Ergomo?
DA 9 is octalink. There are a ton of aftermarket cranks still using the Octalink BB. I’ve used DA 9 and Ritchey WCS with my Octalink Ergomo.
Found this on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=160055733940&rd=1&rd=1
As it turns out that is my auction. I was using 9 speed ultegra on that particular ergomo and it worked perfectly. I was looking for an FSA superlight crankset, but they seem to be few and far between. The Dura ace nine speed stuff would work awesome too, just if you are running ten speed throw some ten speed rings on there and they will work perfectly. If you have any questions feel free to holler. Its a great setup and I believe comes out to be a tad lighter then an srm pro. Peace
I went from DA to FSA/Ergomo. I got team super light cranks from a year or two ago with a k-force series ring and they look gorgeous. Replaced the rings with q-rings now and like them even better. My FSA cranks have been problem free and it seems that the main thing that goes wrong with most cranks is more BB issues than crank issues. You do face the possible debonding of the pedal insert but that’s pretty rare except for the super duper light stuff.
are they called “team super light cranks”?
yeah, those are the ones, you can find good deals on them online. I was checking on ebay when a guy posted a lightly used pair righhere on ST classifieds.
www.chucksbikes.com has a few fsa carbon cranks as well as some nice Trigon and Pazzaz cranks for $95-195
www.carbonlord.com has some nice cranks too, basically nonbranded pazzaz and Token stuff from what I can seee
