Energy Efficient House
We are coming to a juncture in life where my kids are close to gone and we are thinking about moving into a smaller, snugger energy efficient home that will carry us for the long haul. I am weighing that against keeping our existing home and retrofitting it for efficiency. I’m not sure it can be done to the extent of a new home, but I really like the neighbohood. The current home is 3,100 SF and was built in 1979. It was built at the early days of energy efficiency and has insulation mandated at the time. It also had solar hot water, hydronic heating and solar water heater for the pool. The solar panels for the hot water froze in the last big freeze and I never replaced it. We have added vinyl replacement windows, a gas fireplace insert and fluorescent bulbs. That’s about it. It has a lot of vaulted ceilings, 2 water heaters and 2 dual pack units.
Can a house like this be retrofitted? I’m also interested in adding solar electric and hot water but I’m not sure how these would work in the winter where I live as we often don’t see much sun. Should I mess with this house or just do something smaller an new from the ground up. What say you ST energy hawks?
Any house can be retrofitted to be extremely energy efficient. I’m not sure I would want to live in it while it was being done though.
Your profile says you’re in California, which is good news for you. There are a bunch of programs through your electric utilities and the California Energy Commission that can help you, from technical assistance to rebates on the work done.
The best thing to do is get someone to do a blower door and duct blaster test on your home to measure and assess the tightness of the building envelope. When they do the test, make sure they work to identify where the leaks are, not just measure the leaks. Once you know where the biggest and most important holes are, you can work on fixing the air barriers. For the building envelope, you’ll want to fix the air leaks that are highest in the house. The stack effect shows that hot air rises. And as the warm air rises and leaves your house it draws in air from lower levels. Plug the holes in the top and you get less air infiltration lower. Look for chases that are not capped. These allow the attic to connect to the home where the walls are uninsulated. We find that all the time.
For the ducts, they are more difficult to fix, but very important. Numerous studies show that duct leakage accounts for an average of 20% of your heating and cooling. That means for every $5 you spend on AC, $1 is lost to the attic or elsewhere due to leaky ducts. Plug those holes and you save 20% and make yourself more comfortable.
While they are doing the blower door and duct blaster, have them pressure balance the home. That will be your best bet in making sure each room is near the thermostat set point. Most homes have a room or two that are really hot or really cold. Balancing the pressure will help, if not fix the problem.
Once you’ve gotten the house air tight, you may want to consider fresh air ventilation. This seems counterintuitive, but you need fresh air to remove moisture and pollutants from the house. When the air comes in on its own, you don’t know about the quality. If you have a crawlspace, the air travels through a damp, moldy, musty area, bringing all that into the home. By planning your ventilation you can run it through your filter system before it gets into the house.
If you want to check your insulation, find someone with an infrared camera. They can go walk around and show you where there are gaps. We find that a lot of insulation is installed incorrectly. If the insulation is not touching the air barrier it serves no purpose. The IR camera can show where those problems are and may help you figure out a way to fix them. Blowing insulation into wall cavities is usually the way to go, but each case is different.
Now, that may seem like a lot of work, and it is. You may want to look at a smaller, newer home. In California, many of your builders are adopting some good energy programs. Look for performance guarantees on the heating and cooling bill. Those homes are not only more energy efficient, they also are better at dealing with moisture, quieter, and more comfortable.
Good luck!
How much would a proceedure like this cost??
Unfortunately, all I can answer is “depends.” For a new house, we can do it for less than $2,000 and some production builders are finding they can do it at no incremental cost (there are some increased costs but they are paid for with fewer callbacks and homeowner complaints they have to deal with).
In some states where there has been an emphasis on infrastructure development, you can get people to do the tests for $100 or so (the infrared camera tests are getting cheaper and cheaper. The cameras have come down from $14,000 to $2,000 in just the last 5 years). Other places may be more expensive. In California, I think the tests can be partially paid by utility or CEC efficiency programs as long as the homeowner implements some of the changes. It all depends on the state and utility. I don’t think you’ll be surprised to learn that MO is a bit behind the curve on things like this, although St. Louis may have some availability. It seems strange, but one group you might want to check with is the local Habitat for Humanity chapters. Many of them now do these tests before occupancy. You may be able to hire their crews to check your house.
One thing to look at is the value you get from having this done. There will be some energy savings, but the payback is in years. If you only see that as a value it won’t be worth your while. But if you value comfort in your home, reduced likelihood of mold growth, improved air quality, and durability of the structure, then you can get a better appreciation of the work.
I can only image where MO is compared to the rest of the nation on a deal like this. We moved, in the fall, from a brand new home that was tight as a drum, to an 80 year old home the is like swiss cheese. It is really strange, but sometimes we can feel a nice cold breeze blow through the room (maybe it’s a ghost!!). Some rooms are definately colder than others, by a large degree and I am really concerned about the costs to cool this house when the summer rolls around.
Oh boy. I don’t even know where to tell you to start. Are you a DIY-er?
Has the house been updated? Is it even insulated?
Back in the day, before AC, it was actually helpful for houses in the south to be “airy” to allow for as much breeze as possible during the summer. But I don’t think you’re far enough south for that.
I guess you can work from the top down. Start with air sealing. Your light fixtures are probably a major area of air leakage. But be careful, some older fixtures get too hot and need a buffer. Newer ones are ok.
Tough stuff.
The best place I know in your state is the energy office. http://www.dnr.mo.gov/energy/index.html
They are great people, but they have very few resources to help out. I think they are down to only a few people in the office due to budget cuts over the years. You can ask them if they have a list of qualified HERS raters you can hire to take a look. Interview these people so that they provide guidance and not just a measurement of the home.
Does the solar power and water heating work well with cloud cover in the winter? My prior experience says “no” but that was a 1979 vintage unit and maybe things have progressed since then???
Thanks for the info. I can handle some DYI jobs, but I really have no idea where to start when it comes to sealing this house up. Unfortunately, the wife loves the old windows, chains and all. I have been repairing and installing the storm windows, which are on hook and eye fixtures. The air conditioner and furnace are new as of 5 years ago, new roof 2 yrs, some new electric and plumbing 2 yrs and an additon 2 yrs.
For the past two weeks, I have been repairing plaster in on of the bathrooms and one of the bedrooms. What my wife sees as charming, I see as a PITA and endless work.
I’m not that familiar with residential incentive programs in CA, but I would highly recommend contacting your local utility and spending some time on the california energy commissions website. http://www.consumerenergycenter.org/
(I browsed that website, which has good tips/ideas, but looks a little light when it comes to $).
You may be better off with an instantaneous hot water heater. If you’re in an area with a decent amount of cloud cover it’s very difficult to determine how much, if any, passive solar will heat your water. The decision will probably come down to replacement costs, though. If you can replace the tubes inexpensively, it would probably be a good investment even though you can’t be sure they will perform as you might wish. I might also add that instaneous water heaters and passive solar water heating tubes are basically mutually exclusive. If you have close access to your shower/dishwasher drain, you could create a heat exchanger using the heat from waste water to warm water coming into your hot water heater (unlikely but worth a look).
I would highly recommend stuffing as much insulation as you can in your attic. Most heat gain, especially since most residential homes have dark shingles, comes through the roof. You should also focus on keeping direct sunlight out of your windows by using shades/awnings.
Even though I think photovoltaic panels are not the best choice, CA is basically giving them away so I would also recommend looking into that.
I think art answered much of that. Again, much of what you ask is answered as “depends”. Solar water heating makes sense for many people, especially when you’ve got huge incentives to install it. Most of our installations include a backup gas or electric heater. Adds to the cost, but keeps the wife happy (you decide which is more important).
Solar as an electric generator is generally not cost effective. But if you find value in using it that’s great. Plus, California is spending about $3 billion on PV, so you may be able to get some great deals.
The key is to cut your consumption, then it is easier to serve that consumption with solar water or solar PV.
