Eliminating spacers
If you eliminate spacers, do you have to worry about adjusting everything else on your fit?
I asked this same question a couple of weeks ago. It was within another thread, though, but did get one response…
http://forum.slowtwitch.com/gforum.cgi?post=1388146;search_string=gienopes;#1388146
What did you end up doing? Did you move your seat forward at all?
Well maybe…if you remove spacers then you are lowering your cockpit height and incrementally shortening the hip angle. In reality unless you are dropping a significant number of them (i.e. over 1cm), I doubt it will have big impact on angle. The change for me has always been effect on neck muscles. Your neck may feel sore until you adapt…at least that is my experience.
