Elbows high/elbows low/please tell me which way to go? (swim q)
Two video’s/images i’ve looked at this week:
#1 http://www.youtube.com/watch?v=7dJs0ToB_z4
When they show a view underwater, from the front, his arm is extended well into the water during the pull, with a nearly straight elbow angle.
#2 http://www.svl.ch/CrawlAnalysis/
Particularly image 6, they mention how his elbow nearly breaks the surface, and how it’s bent at 90 degrees.
So, which is it? Does it vary based on distance - is one more appropriate for long distance vs a sprint?
In the Bill Kirby video, the thing to notice is that he is not “dropping” his elbow. Even though he is using a nearly straight arm pull, he still holds the water through it.
The thing about the tecnique of both Hackett and Kirby is that it takes a lot of strength to pull the water like they do. Also, Kirby’s tecnique puts a lot of strain on your shoulder.
Ed
http://i5.tinypic.com/2drx3zn.jpg
This is a high elbow - signified by a straight line acrossed his back to the end of his elbow.
What makes you say they’re different?
As they pull they both have their hand and forearm closer to the bottom of the pool than their elbows. That’s high elbows. Dropping your elbow is when your elbow goes below and you wind up leading to some extent with your elbow. That’s how you give up power.
The really nice thing on the Youtube video is the snap at the end of each pull. That’s power.
Nipsy,
In structural terms there is something called “scapular plane”. Briefly, that is the natural arc that comes off your shoulders (which are slighly rounded). Imagine laying back on a 1/2 a hoola hoop or laying in a satellite dish. Any movement pattern that punctures that natural arc is “not as effective” as movements that stay within it. This applies to the elbow joint as well. Anything beyond (in either direction) from full extension is not as effective.
Please take this for what it is worth as I dont like fixing swimming issues by making appendicular adjustments. Swimming should happen from the inside to the outside, so you are using first class leverage. That said, the arm movement should not be anymore complicated that if you were making snow angels while laying inside that hoola hoop.
I know this will seriously upset alot of people and challenge the typical paradigm. But I am trying to simplify something here that has been seriously over complicated.
So try to do those movements. Lay down and make a snow angel with a fully extended elbow/arm. Then elevate your arms off the floor and do that movement where you can see your hands. Then try it standing up. When standing try to puncture that scapular plane, you will feel it become harder to elevate your hands over your head if you are outside of this.
Now make the movements with one arm starting from the naval and one starting from overhead. (alternating). This is the swimming movement your arms should basically be doing when you are swimming (horizontally) in the pool, with a general “facing of the palms” towards each other.
What you are seeing in the videos and the pics are amazing athletes with talent and gifts that neither you nor I own. Keep that in mind when watching the best.
All the best,
DaveD
i’m probably the worst swimmer in the world so i can’t give you any advice, but I got this link from my brother and it got a nice 3d view of swimming. you can choose yr swimmer on the left (the rest is in chinese, so i have no idea what it says): http://www.swimming.jp/3d_mv/3d_index.html
no, that is a waste of energy.
plus it is often misread by swimmers for what it really is.
elite swimmers do get some propulsion out of that but are blessed with the ability to manage the time it takes and energy it takes to lift the arm, and carry that weight until it is back out in front. They do this through a kick that is similar to the power that elite cyclists have…in that we can mimick them all we want, but we will never have that power and feel to produce the same output.
all the best,
daved
I say they’re different only because one has a bent arm, and the other has a much straighter arm. i suppose the point is that regardless, their arm is perpendicular to the bottom of the pool.
Japanese not Chinese, but that is a really cool site.
Hey Nipsy,
Elbow bend is pretty variable in the same way that optimal gearing for cycling is variable.
More bend = less leverage on the water but more efficiency (arm is pushing water directly back through more of the stroke)
Less bend = More power, <efficiency.
Therefore, it will typically be a function of strength and distance of the event.
90-130 degrees at midpoint seems to be the general range.
Hope this helps.
Alan Couzens
ASCA II Swim Coach
I’m not an elite swimmer anymore, if I ever really was, but I still pull all the way through. Not with power I used to have though. Still, I can’t see any reason to want half a stroke, power comes from entry to exit, more contact with the water = more power speed and efficiency. Because I pull all the way through, these days I swim 25 meters in 14 strokes. When I get tired my stroke shortens a bit and I drop to 15 strokes, less efficient. You’re right, most of us won’t have as much snap as you see in the video but we should be trying to swim fast and efficient, it is a race after all.
Excellent, good to know.
Actually I am saying to cut the stroke length down, but not the quality of the anchor. People always get these confused. I am saying that your anchor, once set, then moves AWAY from your body. You will not be able to take that anchor and move it underneath you and push it towards your feet. That is what the “finish your stoke past your hips” is saying. I am saying remove an LINEAR path with hands, or dont force one. What I am saying will feel like you are cutting your stroke (for those in TI or other DPS mentalities) But actually what you are doing is reducing the time that you have to carry that arm weight above the water and lessen the chances of punching out of your scapular plane. 2 items that are not effective in creating positive aquatic experiences.
But again, I dont want to get caught up in over complicating something that should be simple. To the OP, just try what I am asking…what is that going to hurt? You never know what you may find…input in/output out…and now we are growing.
DPS is a myth that is propogated by safety and primitive brain function and marketed by manufactures that make money off products that try to enhance that. I will say it again, swimming should be like walking. Basic, functional and effecient. You dont walk around doing distance per stride so why swim that way?
all the best,
daved
Legget24, I grew up as an age-group swimmer, pretty competitive, but not truly elite. I also was always taught to push all the way through the stroke. However, in the last 2-3 months, I’ve started to change this and focused on quicker recovery. I’m getting faster…my all-out 100y time has dropped from 1:05 to 1:02 and my steady 100 pace is about 3-4 seconds faster. just my 2 cents. Seems counter intuitive, but its working for me. FWIW, I’m 6’2 and used to swim 25y in 13-14 strokes, now I’m right at 15.
The reason it seems counter intuitive, is cause you think your pushing water. My understanding is your not. Idealy you anchor your arm/hand in the water and pull your body over it. When done correctly by the best, their hands actually leave the water in front of where they put there hand in. Think about that there hand actually moves forward, not backward.
you’re right…that’s the mental leap I finally was able to make and its paying off.
Well done and thanks for backing me up. Taking and extra 1.5 strokes per length actually made it easier for you! so you could then go faster…fantastic.
daved
That ‘touch your thigh’ thing has been shown to be slower, as well as causing more ‘snaking’ in the water. I have a hard time NOT doing that, since it was ingrained.
The hand doesn’t move forward. the hand enters the water and goes forward 18-24 inches, or sometimes more, before the catch and pull begin. It also, often goes forward from the end of the stroke before exiting the water, but it moves backward druing the stroke. The better the swimmer, the less it goes backward and the more it appears to come out ahead of where it went in. Swimmers who reach well forward underwater, e.g. TI, give the same impression.
