Either one of these bikes worth purchasing
http://i12.ebayimg.com/03/i/02/5d/d5/6d_3.JPG2005 Dawes Lightning $245 … frame sizes 50, 53, 56, 59, 62
Full Chrome-moly Dura-Forte Frame and fork; with Alex Aluminum rims, Shimano Sora 24-speed der’s with downtube indexed shifters, Maxxis 130 PSI 700c tires, quick release wheels front and rear, aluminum alloy hubs, SR/Suntour aluminum crank, Aluminum alloy pedals including toe clips with straps, aluminum stem, aluminum handlebar, aluminum seatpost, ProMax aluminum side-pull brakes and levers, plus a very nice Velo Road bike seat.
http://i23.ebayimg.com/01/i/04/30/37/e8_12_sb.JPG
Motobecane Mirage Sport … 54, 56, 58, 61, 64 fram sizes. $325.
Frame is 7005 double-butted ALUMINUM. Specs include a sloping crown chrome-moly fork; Aluminum black quick release hubs, Aluminum Double Wall Rims with CNC sidewalls; 24-speed SHIMANO SORA DER with RPM CYCLONE ALUMINUM Alloy crank, high pressure 23C tires, aluminum black handlebar & black seatpost, with a great comfortable seat with pressure relief design and Toe Clips with straps. SHIMANO STI SHIFTER~BRAKE LEVER COMBO - this bike has the special SHIMANO levers where you shift and brake from the same lever.
http://i22.ebayimg.com/03/i/03/16/0c/96_12_sb.JPG
Full Chrome-moly Dura-Forte Frame and fork; with Alex Aluminum rims, Shimano 2200 14-speed der’s with stem indexed shifters, Maxxis 130 PSI 700c tires, quick release wheels front and rear, aluminum alloy hubs, SHIMANOaluminum crank, Aluminum alloy pedals including toe clips with straps, aluminum stem, aluminum handlebar, aluminum seatpost, ProMax aluminum side-pull brakes and levers, plus a very nice Velo Road bike seat
$199 62 cm frame
if you want a bike to ride a couple times a year for a “recreational” ride then they are fine. But if you are looking for an entry level race/training bike, they are not the answer. They, more specifically the components, will fall apart and require alot of tuning up/ repair/ replacing to keep in good running order.
What if a gradual process of upgrading components is part of the plan? I’ll likely need to do the same thing with 20-year old Raleigh road bike I am currently using.
