Effects of changing stem angle
I am currently using a 120mm stem with -10* angle.
If I were to go to a -17* stem…
  1. How much would it end up lowering the front?
  2. Would I stick with the same length or go longer?
NOTE: I don’t plan on moving the saddle forward much. I’m already riding at 80* effective STA.
Thanks.
Steve
http://www.habcycles.com/fitting.html
Ask and you shall receive.
Thanks!
Steve
this isn’t exactly what it was you were asking about, but i found out something sort of interesting in the last week. i’ve been riding my road bike with a -17 and 3.2cm of spacers. i moved to -10 and 2cm of spacers or thereabouts, to get about the same coordinates, but with less steerer under the stem.
with the spacers and the -17, if i rode with one hand on the bars and the other not on the bars, i had a slight wobble. not a death wobble, but the precursor to a death wobble most likely (should i do this at 45mph instead of 25mph). with the -10 and half the spacers, same thing, but no wobble.
i sort of expected this, but at the same time was a little surprised when it occurred. i’m not a fan of spacers, but this little experiment was another validation of that sentiment.
Spacers? What’s a spacer?
You know, those things you put above the stem before you whack off the last centimeter or two.
http://www.zinncycles.com/stemFit.aspx
"To use this executable Web calculator yourself, you first have to figure out where you want your bar to be. You will need to know the head angle of your bike and the angle of your existing stem. "
