Easton attack TT bar...reviews
Saw these pictured on the Elite carbon razor review and in the interbike section in the latest Triathlete mag with Normann on the cover. Anybody using these? How adjustable are they. I really can’t tell from pics I can find on the web.
Not very.
I am planning on getting a set once I have my bike fit dialed in on my new ride. There is no adjustability in these bars.
got one…adjusted it…love it
We just got a set in for a customer. First thoughts, damn light. After chosing the extension length the only other adjustment is pad width. It can be adjusted from 22cm to 29cm (outside-outside), and has an extra set of spacers to raise it up to a total of 1 cm above extensions. (but who on this board would ever go up)
how do you measure to know what extension length you need?
Nice if you ride low and narrow and do not need a lot of adjustment. They work best if you make a “custom” armpad. I made some out of the vision micro SL pads. Theaston ons are way too thin.
They are light-
Are these different from last year’s model? If so, do you a link or some pics to post? And how are they different?
Watch out on length,; they run grossly small. What they are calling a medium is really about the length of a Vision 230 length.
They are light and look cool.
Lots of adjustability on an aerobar is a bad thing. It just adds weight and complexity and areas that are more prone to fail or corrode. Find a brand that sells your size, not a brand with one size fits all (poorly).
All new. Check out eastonbike.com
http://www.eastonbike.com/images/P-bars/bar_attack_TT_RA.jpg
Nice, I like. Do they come with the same lame brake levers as the standard Attacks? Are those cable guides below the bars? Why would they have those there instead of routing the cable through the middle?
As you can see, its all new and different. You use whatever brake you llike. I like the new Profile carbon brake lever (I also liked the old Easton Attack brake).
The nobs halfway down the extensions are for internal routing. The barend housing almost always starts outside and then enters several inches down the extensions. You just bar wrap over it and it has a great look and feel.
