Easton Attack Sizing?
Has anyone measured the difference between a Large and Medium. When I measure my forearm and compare it to the easton chart I’m a medium but one cm away from going either way. Since everyone says they run small do I just go with a Large? Can the extensions be cut? If I cut them will they then be the size of Mediums is what I guess I’m trying to get at.
Thanks
I can take a measurement for you later on the large. I was in the same boat (about 1cm short according to Easton’s sizing) but decided to go with the large. It was definitely the right choise as it fits really well.
-Mike
I measured two different ways. Once the way easton says to with your hand in a fist and came up with only 38cm which would seem right for ski bend bars. Then I measured with my hands in a positing I would most likely ride in (think s-bend) and and came up with 41. So that would but me in between. So that is why I was thinking large would be the way to go.
I am in between the small and medium and ended up getting the large since that was the only one in stock. I thought I would have to cut it but am yet to take a saw to it. Needless to say I am happy I went with the large
