Easton Attack Pad Riser Kit
I do have the Easton Attack Bar.
This Bar comes with 4 spacer to rise the arm pads.
I am looking for 4 more.
I called Easton and they toled me to order via my local Bike Shop.
So I went their and after a week they came back to me saying that Easton is not able to get them, as they do not produce the bar any more.
Does anyone know where I can get them, or is willing to give theirs to me?
Thanks in advance
Kim
http://i27.tinypic.com/25yvr6x.jpg
I have some you can have, email me your address kervin@rotorbikeusa.com
I’m in the same boat as the OP and need 4 more of the Easton spacers.
PM me your address. I am pretty sure I have extras
Bringing this thread back up as I too need some spacers…at least 2 please?
If you need more than the supplied amount you are likely using the wrong aero bar. You will have downward sloping arms.
Use the supplied amount- also get the cee gees pads for Easton (about 4x thicker than sotck)- need more? Wrong bar-
too funny :wink:
Damn!
I got 4, best go check out the postage costs to US and put them on Ebay!
As you modified your spacer thing BIG time. You have the wrong bar at last in the opinion of the user above my last post :-)))
:o) Don’t you just love the experts that don’t know about an individual’s personal limb lengths, muscle bulk/mass, range of movement and flexibility yet insist on telling you what you are doing wrong and often not adding anything constructive to the thread. I think one of the moderators referred to it as winter cabin fever.
As I’m sure you already know owning a set, Easton Attack bars, whilst very light are not exactly that adjustable are they. I found (quite a while after the fact) that I could have done with longer extensions and a shorter stem to move the arm rest position back so I made my own pad hangers to move the pads back and wider whilst leaving the rest of the bike set-up unchanged. The 2 additional spacers on the front were temporary to deal with a lower back flexibility issue and have since been removed leaving the lift the same as using 2 standard spacers with an angle adjustment using the wedges at the back.
On a practical note if you can’t get any, you may be able to purchase a small amount of laminated carbon sheet in a 4 to 6mm thickness and use your original ali spacers as a template to cut a couple of ‘egg’ shapes, drill some holes and make up the additional height.
You’ve got a wicked set of very light bars there so if you don’t want to, don’t change them. Do your own thing ;o)
