Just upgraded to E-tap for my Shiv. Wondering if anyone has any useful suggestions for installation, blip box placement or some other hack I might find useful, etc.
Thanks
Andrew
I bought a k edge stem mount and attached it to that, it sits over the nose cone.
Couldn’t you put the blipbox in the nosecone cavity? I wish i had the nosecone version. Don’t suppose you’d give the dimensions of it? I’d love to have someone 3D print it
There was person who posted his Nosecone/blip box install in the “show me your 1x” bike thread. Fits in there just fine, but you still need to route the cables from the bars into the nosecone. I tuck mine between the top of the bar and the inside of my wrist, but my bar setup is weird and custom.
I am going to use this as an excuse to post this again
Beautiful. And clean.
SHIV Tri or SHIV TT??
I cant be bothered with reducing image size or tinypic. So here’s a gallery of what I did. I just used double sided sticky tape for the blip box mounting below the bar. It holds well enough that it’ll be hard to actually take it off. But still gives me easy access.
Off topic, but why are the RD pulleys so elongated when you’re in the smallest cog? Isn’t that chain too short? Or does it have something todo with the oversized pulleys?
Can’t answer to that. The best mechanic in Tulsa built it up, so I have to assume he knew what he was doing.
Ya I run the same setup but mine looks more normal, but I will admit to being a mechanical hack.
…I wish i had the nosecone version. Don’t suppose you’d give the dimensions of it? I’d love to have someone 3D print it
You & me both!
Dang that a sweet bike! I wish I could find a used nosecone for mine.
