I’ve just burned through another pair of (big) shoes. I murder them in in 150-200 miles, wearing the outer edge of the sole down to the foam. In the last 2 years I’ve killed DS Trainers, Brooks Axioms, Mizuno Wave Riders, Vitruvians and Saucony type A’s. I’m 6’2", 195lbs, do 20-30 miles a week, and I’m in 41 minute 10k shape. I’m lucky in that I don’t need much shoe - I’ve trained lots in Puma H-Streets, for example. I’m unlucky in that I can’t seem to make my feet land flat - I’m on the outer edge most of the time, and I’m a forefoot striker, so that makes the contact area even smaller.
I’m about to embark on another 100 runs, 100 days epic, finishing up with a marathon. The last time round dropped me 10lbs and 20 seconds per mile, so it’s totally worth it. That’ll be 700-odd miles of running in total. I’m doing the math, and that’s 400 bucks’ worth of shoes, not to mention all the ice cream and mexican food.
I just want something with an indestructible sole that will go a lot of miles before it dies. The Honda Civic of shoes, if you like. And cheap. And maybe a bright color too, as this amuses my children greatly.
Apply this to the outsole of your shoes when they are brand new. Completely cover the areas that tend to wear down the fastest. Put a good coat on there. Wear them for 10 to 20 runs. Then re-apply. Takes about a day to dry. You will more than double the life of your shoes.
Before I started using Shoe Goo, I used to get a maximum of 300 - 400 miles on a pair of shoes, usually 300 or under. Now I generally get at least 1000 miles unless the midsole material completely sucks.
I have a pair of Nike lightweight trainers that I’ve done this too since I got them. I’m over 1700 miles on them. Yes, 1700 miles. The upper is starting to tear now though so they’ll be gone soon. But the outsole is pristine.
Wow - that sounds interesting. I’ll go but some Shoe Goo. Have you found that it works ok if you wear the shoes down a bunch first, and then apply it? I have a bunch of pairs that could be rescucitated that way. Thanks!
Some people do it for that but it’s not as good for it, in my opinion. It’s better as a protective coating over existing outsoles rather than as a replacement for them. Still, give it a shot. Won’t cost much.
Hey Bigshoes. I use Asics gt21 whatevers. I’ve used them since the were 20xs. I’m 225-255lbs. over the years. They last about 700-800 miles on me. I’ve tried other shoes over the years but always go back. Good luck. Oh yeah I’m a size 12 EE.
