We ran some tests last week to illustrate drafting, and thought you might want to see the results. The CdA was measured with our Track Aero System at the VELO Sports Center.
The test:
Little guy (red) rides in front of big guy (turquoise)
So that’s why I look like “dinnertime” to the little guys. What was the approximate distance between riders? Do you perhaps have three and four rider trains planned?
Did Tom Rodgers lend his “expertise” as a drafting test subject?
His type are the reason I asked Jimmy for recourse. Having talked with Andy for years now, and seen some of this data before, the benefit drafters get can be quite predictable. At Cozumel last year, a Texan AG winner magically biked 30 minutes faster. Like you, I exchanged words with the drafter. FinisherPix documents the draft pack. Unsurprisingly, the racer’s Kona bike split is an hour slower than the Cozumel draft-inhanced split.
It would be helpful to have some numbers and not just the graph. I think the graph is a little misleading. It looks to me like the delta for each rider is about the same when going from non-drafting to drafting. It is just that the big guy has a much larger CdA. So something like:
Non Drafting Drafting
red .25 .20
turq .28 .23
When you put them next to each other (.25/.23) and (.28/.20) it looks like the benefit for red is huge .08! while the benefit for turq is small at .02, but this is misleading, the benefit for both is .05.
Andy, when the Milton Velodrome opens and I get a chance to spend some good time on it, I’ll be doing stuff like that. In the meantime, everything I’ve posted has been paid for by someone else. I have had to ask for permission to post it.
