Downsides to Zipp 2001 frame?
Just curious what Zipp frame owners have to say about the downsides (if any) to owning a Zipp carbon frame and beam. I am thinking of purchasing one for a tri-race bike, and was wondering if it requires a lot of wrenching/maintenance (similar to what I hear about Softrides). The fork and headset are fairly new/threadless, so that’s not a factor.
Once it is properly built up & initially fitted, how much or how often is maintenance required? I will do mainly local races, so re-assembly is not an issue once it is built.
Only current/previous owners/riders of Zipp frames need respond…
Thanks,
Keith
Here are a few things that gave me some frustration when I owned a Zipp 2001 (in no particular order):
  1. cable routing…mine had a kink in the rear derailleur sleeve in the frame, it was a PITA to route a cable to the rear derailleur. The front derailleur and rear brake cables were easier. If you’re buying a frameset, you might want to check that out first.
  2. the rear brake’s braking power sucked. Not a big deal, as I don’t use a rear brake in most of my other bikes. It was strong enough to stop a wheel from rotation when spun off the ground at “bike checks”, which is all it needed to do for me.
  3. the beam moves laterally…not a whole lot, and there are things you can do to remedy this.
  4. the bolts that hold the seat clamp to the beam tore up the inner thigh part of my shorts…albeit I like to pedal with my knees close-in, so this may not affect everybody
  5. adjusting the seat height was kinda of a pain, as you had to rotate the elastomer thingy close-wise/counter-clockwise…but you have to remove the beam each time to do it. Not all that hard, but not as easy as a regular bike. But that’s one of things you pay for…
Regular stuff is easy…not much different than a standard frame, other than needing to find way to hold it on your workstand. I clamped around the nose of the seat with my Ultimate…worked well enough.
In short…despite the mechanical idiosyncrasies due to the design, it was easy to work on.
Good luck.
Dave
