Downhill Chicken question
Coming from a running background I’m very new to this cycling mullarkey. I went on my first group ride this weekend on a popular loop north of San Francisco. There’s a bit of a hill in the middle of the ride and I found myself passing a lot people on the ascent only to have them all blow by me “on your left” “on your right” “get off da damn road ya pussy!” on the way down.
I just don’t seem to be able to corner very quickly and flying downhill scares the bejazus out of me.
Any tips on how to become a better descender? …testicular fortitude comments excepted.
Well, I’m with you Sir. I had a bad accident in a race in France in 1990 and have been a nervous descender ever since.
In general, I think practicing the techniques for corner on flat pavement in an isolated area is a good start. Find a clean, open corner with a safe run-off area and no traffic, such as a huge parking lot after hours.
Establish a cornering course and then practice the technique. Bring the speed up gradually as you become more comfortable. Keep doing this until it becomes imprinted and feels naturual, or at least, more natural. That should help.
High speed cornering is a perishable skill also. It needs to be practiced to be maintained. I think it is also bst practiced with one other rider as an observer/coach/critic but not with a group that places annoying pressure on you.
High speed cornering on a descent is another dynamic altogether. There are several layers of additional skills you need to develop and the road quality is a huge factor too.
I think what you did was right. Be conservative. Stay in your comfort level. You have nothing to prove to anyone.
Over Camino Alto by any chance?
Practice, practice, practice. Tom is right, practice clean corners in a parking lot to get the idea of weighting the outside pedal and leaning your bike. Then again by yourself do the same downhill and open it up a bit. After a few hundred downhills you will feel more comfortable. Note I still am pretty conservative on downhills compared to my roadie friends. Seems to me as I get older my braveness isn’t as strong as it used to be. g
thats the place.
Here are a few pointers I learned for good cornering: Keep the leg on the outside of the turn straight, and put pressure on it (ie: if you’re turning left, keep your right leg straight and apply pressure. a lot of pressure). The leg that is not straight should be bent, and you should move the knee slightly away from the top tube. Sort of like you see motorcyclists do. Same thing with the elbow that’s on the same side as the bent leg. You move it outward a little. Break before the corner. During the corner you want the tire to have the best possible traction, so no breaking. Don’t pedal (duh).
In a descent: Hug the top tub with your knees. Don’t lock the breaks. Break more with the front break, but don’t lock it.
By the seventy seven hundreth time you go down Camino Alto you’ll learn exactly how fast each corner is, which corner holds water after a rain or heavy fog, which corners increase their curvature once you are committed, the three blind driveways that are potential issues, the two corners with the tire-eathing cracks right in the perfect line causing one to not nail the apex perfect, etc.
A great way to learn descending is to ask a buddy who always drops you to slow up a bit so you can follow their wheel down the hill. This will help teach you the proper speed for the corner, the set-up, the lean, and the exit. I’ve always been a downhill nut, but still love to go to school behind my friends who have a lot of motorcycle experience. It all comes down to balance and faith in one’s tires.
disclaimer: only downhill as fast as YOU are comfortable. I stack hospital good every 3-4 years. It’s all part of pushing the envelope and that damn patch of gravel you weren’t counting on. Last crash was at 50+mph decending King’s Grade in Tahoe. Lots of stitches and a couple of broken ribs. Yikes, that was 3 summers ago.
thats the place.
I knew it. It took me a long time to get to where I just barely tap the brakes in just one spot – the sweeping right turn that’s right after a left (the 3rd turn from the top). And even so, most all my friends sail right by me down it.
Look out for the “15” painted speed limit numbers just at the start of the descent when it’s raining. Way slippery.
yeah, go mountain biking. Turning high-speed in the dirt makes you learn how to lean, shift weight on your pedals, trust your bike, manage obstacles while leaning, etc. Negotiating turns at 60 mph on pavement is easy after you’ve done a 35 mph fire-road descent a few times.
On a totally different tack…I found a distinctive wallet Saturday morning by the traffic lights at the bottom of Camino Alto.
No ID inside just cash…if you know of anyone who lost said item IM me and I’ll return it.
I’ll refrain from the “it’s mine” jokes. That’s an odd place to find one - not a lot of foot traffic. Maybe came out of a cyclist’s saddle pack. Huh.
I think it came from a cyclist too…looks like a wallet you’d only use on a ride…absolutely nothing in there but cash. I picked it up right at the beginning of the bay trail going towards Sausalito.
I’m definitely not a pro descender (and I’m always thinking “what if I get a blowout” when the speedometer goes over 40), but here are some techniques I picked up mostly from my hard-tail hard-fork mtn biking days. Hopefully, one of you more skillful cyclists will tell me if I’m doing anything wrong. Keep your upper body consciously really loose (hands, arms, neck, shoulders, back - but esp. hands) If the road gets hairy, take some weight off your butt and put more weight on the pedals - absorb bumps and holes (that you can’t avoid) with your knees “Steer with your thighs” (i.e., putting more pressure on one side of the saddle with the inside of your legs). Don’t try to turn the handlebar at all. Look ahead and set up your line as far in advance as possible. You want to let the bike follow as smooth a fall line as possible to minimize the need to make sharp turns and, therefore, big speed changes. Similarly, if you need to reduce speed to take a turn, try to slow down before you go into the turn. Shift your weight farther back on steep downhills. Don’t burn up your brakes – pump them, don’t lean on them. Think Smooth!
OK, flame away. And how do I stop thinking about blowouts?
Lots of good tips already, but I have one that hasn’t been mentioned yet. Try turning your hips away from the turn. This helps to torque your frame and allows you to keep a clean line and allows the bike to do the work. Trust the bike…it’ll turn sharper then you can!!
FORGOT…counter-steer. As you turn your hips away from the turn, counter-steer the handlebar, turn it away from the corner too, this is a motorcycle trick.
I agree that you should ask one of the other riders to slow up a bit so that you can follow. It is much easier to get your nerve up if you are trying to stay with someone. If you just have a problem with being nervous at speed I suggest you find a good rolling course that has big enough hills to get you up to speed for a moment or two then levels off. There is a great stretch of road for this in the east bay. Ride on Skyline between Redwood and Golf Links road in Oakland. It has 4 or 5 spots where you can easily get over 40 mph but then it levels off or goes back up hill.
http://www.slowtwitch.com/mainheadings/techctr/descending.html
Camino Alto is fun, but you should really practice descending on Panoramic Highway after going up Fairfax-Bolinas Rd. Now there are some good switchbacks.
If someone is heavy enough to to pass me on a long downhill (assuming we have spun out), then I usually figure they are heavy enough that I will catch them on the next uphill . . .
Serioulsy, if you are nervous, stay out of the way until you are comfortable (as stated, practice alone).
I moved from a flat area to a location where I have a 60mph downhill less than 2 miles from my house. I think there may be a negative correlation between “brave” and “smart” when downhill/corning are considered.
All the suggestions offered here have some validity, but you can spend years practicing all of them and still not be able to handle downhills comfortably. The reason for this is that the secret to fast cornering is not in any of the techniques others described earlier, but in training your gaze: you go where your eyes have fixated on, and until you learn how to correctly focus your gaze you will never master corners.
The technique is simple in concept, but very difficult to implement: fix your gaze at the exit of the corner.
When you first try it you will focus at the exit… but not really. You will be forcing yourself to look there, but always glancing to the side thinking what would happen if you exited the road. You have to expend a lot of mental effort to focus all your attention to the exit of the corner, to the extent that you are not aware of your other surroundings. It will really feel as if the rest of the world is not there – as if your entire world is that piece of road; you don’t think about speed, obstacles, falling, what’s outside the road… you name it. Don’t worry, your peripheral vision takes care of sideways dangers without you consciously focusing on them. It’ll take months or years to master this, but you will not only become faster than most people, but it will feel effortless and utterly natural. Trust me, the moment you get it you’ll know it! – it’s a zen moment that you will never forget.
Once you get there, you will also realise that all the other tricks (weighing the outside pedal, countersteering, braking, etc.) in the book are inconsequential: they automatically fall in place without you thinking about them.
Once again though: it’s not an easy thing to master. My suggestion is to try and incorporate this into all your activities so that it becomes second nature, and not something that you only employ on the bike. Practice the technique in your every day driving – every single time you sit behind the wheel. Do it during your runs too, look straight ahead or up a bit – don’t look down.
Having said all that, I need to caution you on the end results: yes, you can become very fast, but whether this is a good thing on a road bike is debatable. I learned this technique when I was racing dirt bikes (and when I really mastered it I started earning medals), where crashes were plentiful but harmless. I still use the same technique when mountain biking because I wear full body armour, but on a road bike I feel naked, and just a small piece of glass away from losing tire pressure and crashing; there are so many things that can go wrong on the road, and road bikes are so much more fragile and delicate, that I don’t believe going really fast there is worth it.
Good luck in whatever you try.
John
Testicular fortitude? When descending, it’s better to have brains than balls. Also a good idea to use some kind of tire liners (I use slimes for training) because a front flat will have you eating pavement.
Some good suggestions out there already, but I didn’t see this one. Shift your head (and therefore your weight) to the inside of the turn. Counter-steering very slightly, because you want to steer with your weight, not your front wheel.
Don’t be shamed into going too fast, because crashing at speed hurts a lot, and worse than that, it can f- up your bike. Practice, practice, practice.
