Don't have a friend? (To hold your Crack Pipe)
For those of you who without a friend to hold your “crack pipe” (while inflating your disc wheel). Here are some alternative solutions.
http://i57.tinypic.com/xkvu5x.jpg
Clockwise from the far left:
  1. If you have a compressor, you can make one of these for about 20% of what the PARK inflator costs. This one uses a regulator to allow a pre-set of the pressure you want. It’s made using a Harbor Freight “Blow Gun”, an older Silca Crack Pipe, some quick detach fittings and a pressure regulator from Home Depot. It turns out the threads on the crack pipe match the threads on the blow gun. Works really well, just press the crack pipe onto your presta valve and pull the trigger - in seconds you tire is inflated to the correct pressure. BTW you don’t need the quick connector between the regulator and blow gun, but I use the regulator for an air brush also, so the connector is needed.
  2. This one is a modification of an older style Silca locking head with the lever attached at an angle. So when the head is locked on, the lever doesn’t stick straight up. Works OK, but is still a little tall.
  3. The new Silca Crack Pipe. This has been discussed on ST before. It works great, but I’ve found it a little fussy to get right.
  4. The new Silca “Hiro” pump head. I believe this is the best possible solution available for discs and general use. It won’t blow off. The only down side is cost (which is greater than 99% of the pumps on the market today)
  5. A hand made pump head, machined from brass, using a cam and lever to lock onto the valve on in the same manner as the Hiro. This one uses ball bearings on the cam shaft and a new Silca (red) gasket. Works as well as the Hiro, but I’m not going to make any more - way too much trouble.
  6. Here’s one anyone can do. It’s just a ball foot air chuck with clip and a presta-to-schrader adapter. The chuck is screwed to a 1/4" hose barb fitting. If you want to make one of these there are a couple of things to remember: you must remove the little check valve from the chuck (take it apart and the little valve just falls out) and buy a good quality ball chuck. I’ve tried the one from Harbor Freight (for ~$2.50) it leaked badly. The one I used costs about $8 (http://www.amazon.com/…_30332190_TE_3p_dp_1). This works well and is no more inconvienent to use than a Lezyne screw on pump head…
  7. The Lezyne right angle adapter for their pumps. I’ve found this tends to blow off if it’s not set just right. More like the old Silca crack pipe - works best when held on by a friend.
woah…
awesome post!
Just found this!
I’m looking at making the top left one ---- I have a blow gun part that says 90 PSI max ---- did yours say this too? Wondering if they all say this, or if I just need to buy a new one with higher rating?
Edit: Went to Home Depot and they had nothing. Amazon is my friend, ordered this:
http://www.amazon.com/gp/product/B000H5OLO4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
http://www.amazon.com/gp/product/B001OZJNUS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The blow gun will probably work. I don’t think the psi ratings really mean anything. The key is the threads on the front where the crack pipe threads in. The one I used came from Harbor Freight… The regulator should work with no problems. Just go to your friendly hardware store and get some brass 1/4" pipe thread fittings and teflon tape and you should be good to go.
BTW, my responses may be a little slow - my computer is “in the shop” with a non-functioning keyboard. Have to use my wife’s.
  1. The Lezyne right angle adapter for their pumps. I’ve found this tends to blow off if it’s not set just right. More like the old Silca crack pipe - works best when held on by a friend. You have a photo of the Lezyne Slip Chuck. The Lezyne SPEED Chuck is different and works as advertised. I liked it so much, that I sold the new Silca Disc adapter as this took up a lot of room in the small cut out area. The speed chuck takes up minimum room.
The Sears hand drill pump is another option.
This may seem a bit too simple, but it always worked.
I just took a wine cork and a chisel…
then cut the cork into a half-round. (the “long” way)
then stick this in between the pipe head and the disc opening. Voila.
I use one of these and it works very well.
https://fairwheelbikes.com/kcnc-pump-head-p-2000.html
If you can’t inflate your disc wheel, with a regular ol’ crack pipe, on your own, you need to spend some time working on your 1 handed pump job. Trust me, practicing is … fun.
Brilliant!!
I masturbate a lot so my right hand is plenty strong to do the one handed pump.
Anybody try the new Birzman Snap-it 90 degree?
http://www.bikerumor.com/2014/09/02/eb14-birzman-reinvents-the-pump-head-again-with-the-new-snap-it-apogee/
