Do you swim with your HRM on?
I was wondering if the water really affects Polar HRM. I’ve got a 720i with one of those new soft straps. Can I swim without the chemicals, salt etc breaking it?
I have a Polar to and while I dont use it for my training I have used it in some of my races and it has never affected it
dan
I don’t think it will read correctly. The strap will break down eventually regardless, and I would assume that chlorine will speed this up.
Yeah, I use my HRM for most of my swims. I like seeing the results after :). I’ve had no problems with the strap etc… up until now. I just make sure I give it a good rinse when I’m done.
I find that I have to wear the strap extra tight though because after a strong push off it can sometimes slip down a bit. I generally don’t wear it when I’m doing a long TT for that reason. I will wear it when I’m doing 300/200/100 intervals though. I just don’t push off really hard.
Some people might think it’s pointless but I still like seeing my ave/max HR over intervals, plus recovery HR after intervals.
I got the S710i with the new soft straps. When I got injured I used it in the pool on my aqua-running and had none problems with it. Before diving into the water, I would make sure it was working properly and once inside it worked fined. After every exercise you in the water with it, you should clean it with water afterwards.
I don’t because every time I push off the wall my chest belt (transmitter) slides down towards my waist.
Dave from VA
I don’t because every time I push off the wall my chest belt (transmitter) slides down towards my >waist.
I have an older 720i with the Coded T61? strap. Same thing happened to me. Just wear the belt backward - with the sensors on your back, the elastic strap in front. It works for some people. Don’t know how well this would work with the new wearlink straps. (i’d be worried that it would unclip from the strap).
Oh, to answer the original post. Use the 720 in the pool all the time, no problems. Just don’t press the buttons underwater. Only issue I have is with ocean swimming -Clean after swimming to clear out the salt.
