Do you put Amino Acids in your Infinit blend?
If so, why?
i’m not sure what the potential benifits and cons are. For the record, i’m doing mostly HIM and IM. Based on the feedback in this thread, i may adjust the little slider for my next batch.
If you don’t use infinit, you probably don’t know what i’m talking about… :slight_smile:
I’ve used aminos in my mix for two seasons now. Works for me.
what does it work for?
Well, I don’t have any science to point to, but I ‘feel’ like when I do my hard sessions with the amino mix that I am less torn up the next day, if you know what I mean. I started using aminos in my IninfIT three years ago when my main focus was track cycling (sprinting) and I noticed a significant difference (at least to me). I kept them in my triathlon mix and don’t see any reason why I should not. No problem with digestion, flavor, mixing, etc. In fact, my coach, my dietitian, and my trainer all recommend supplementing with aminos during and after training. I don’t see any downside and there are a lot of potential positives. Either way, you’re stoked with InfinIT. I love the stuff.
I have two blends I use: short course and long.
For long stuff (5+ hour rides, IM, etc.) I add a little protein. The problem with adding protein is the change in osmolarity and it slows the absorption of carbs a little. But, you do get some energy (although much less and slower) from protein (amino acids). It mainly helps satisfy a little feeling of hunger as well and helps with some of the typical bloating/full feeling people get with all the typical stuff they use by the time the 2nd half of the run starts. I also add a little caffeine to all my blends (but you might need to bump the flavor up a notch as it adds a slightly bitter taste). I don’t like much flavoring at all. Basically, my blend tastes like salty sea water :slight_smile:
But, of course, that is the beauty of InfinIT - make what you want! Experiment a little.
amino acids are protein?
Yes - chains of amino acids = protein(s)
chains of carbohydrates = glucose (or sucrose, fructose or bread, etc.)
Do Amino Acids play a functional role similar to that of antioxidants?
No. Very different. Think of proteins/amino acids as “building blocks” for our body, especially muscle injury/damage from training. Most amino acids our bodies can synthesize ourself, but not all (these are called “essential amino acids” and need to come from our diet - hence some issues being vegan). Antioxidants are thought to “protect” cellular damage (i.e. “scrubbing” free radicals, etc.).
I use Infinitt and Branch Chain Aminos daily in training and after races. I have not added them to my Infinitt though. This is because they are gel capsules.
I refrain from adding too much to my race mixture to minimise gastric upset.
