Do you ping going up hill?
I have noticed when climbing steep stuff I hear pinging coming from my wheels. I assume this is rear crossover laced spokes rubbing. Is that normal or does it mean they need adjustment? Would it make sense to apply some kind of lube or are there little spacers you can place in there? Not a big deal really but kind of annoying.
Do you have aluminum spokes? They tend to ping more than steel. I believe that most of today’s bladed spokes are Al.
You also might need to get your wheels serviced. Often the spokes will get noisy when the get tensioned and de-tensioned when climbing if some are a bit loose or they’re not evenly tensioned.
Try a single drop of lube on each spoke nipple.
My bike “creaks” when I climb, particularly when I’m standing, which leads me to believe it’s flexing in the frame. I have an aluminum Cervelo Dual.
Sorry to go off topic, but this reminds me of something funny that happened to me last week. I was noticing every time I got out of the saddle that there was this weird metalic clicking and it was in rhythm with the pedal cadence. It was driving me nuts and I couldn’t quite pinpoint where it was coming from. I figured it had to be in the cranks or the pedals. I stopped half way through the ride and examined everything. It all seemed fine. But the noise continued. Finally I realized I was wearing a new jersey that had a large metal zipper pull. It was flopping up and down in rhythm with my pedaling and tapping against the zipper.
A few days later I had a similar episode, but this time it turned out to be keys in my jersey pocket.
If it ain’t one thing, it’s another.
I am not sure if they are stainless or aluminum. They appear to be annodized so probably aluminium (they are DT if that is a clue). I noticed some wear where the crossover point is. Maybe that is why stainless is better heh?
If this pinging only happens in your easiest gear, it’s possible that your rear derailleur is actually touching one or more spokes, particularly when the frame and wheel are bending under the stress of applying power to climb. If so, you may be able to adjust the limit screw on the derailleur to keep it out of the spokes while still staying in gear, and if it can’t be adjusted out you may have a bent derailleur hanger or improperly dished wheel or some related alignment problem. If it is just the spokes fretting against eachother, they may not be tight enough (general statement) or the tension could be too uneven (the drive side of a dished will will have tighter spokes than the non-drive side, but the spokes on a given side should all be equally tight).
For the frame itself to actually creak, I think it would have to be cracked. Much more likely that some frame-component interface or component-component interface is making the noise - bottom bracket to frame, bottom bracket to crank, chainrings to crank, stem to fork, handlebar to stem etc… Bike frames are great ventriloquists, they can throw the sound so it sounds like it’s coming from somewhere else.
It may be your magnet hitting your speedo sensor as your wheel flexes under load.
Jeez, I hope it’s not cracked! That would suck! I’ll have to look it over!
