DA Di2 was first generation in some ways, and Ultegra offered a chance to rethink some of this. The main difference is they went to
a 2 wire wiring harness with Ultegra Di2 vs the 4 wire harness in DA. Everyone assumes at some time there will be a new rev of DA designed around the
2 wire harness…that is not yet announced but rumored around late 2012.
Until the two systems utilize the same wiring harness, they won’t be comparable, hence the need for the ‘hacks’ like the Ultegra TT shifters.
I did not use the system checker but after looking into its capabilities, it does sound interesting. Looks to be fairly cheap and can check all the components at the same time. Thanks!
I’ve been doing a bit more digging around and looking at prices and so on. My thinking so far:
If I do it, there’s obviously a risk of breaking something expensive. I guess that is partly mitigated by there being some sort of chance that some shimano TT shifters will come out some time and so if I only break the shifter controllers its not too bad. The cateye remote buttons aren’t available in the UK from what I can see but I know what you mean now so I could create my own.
I like the sequential shifting mountain bike that has already been developed. That’s got to be the way to go. There seems to be two ways of doing that. The inline way and the canbus way.
Starting with the inline way, at the simplest, I just need to come up with a decision tree to move the front and/or rear derailleur depending on what gear I am in and whether it is an “up” or “down” command. However, I am not that good at doing that with simple components (I’m bound to get it wrong n+1 times) and so I was looking at an Arduino. This is a cheap open source prototyping platform. It is easily programmable and has built in input/output ports. I need to do some more reading but it seems like it should be relatively straightforward to get it to read two inputs and change four outputs. It’s also got the handy feature of working on the same voltage as the shimano battery. There’s also quite a bit of open source code for it to give me clues how to programme it (e.g. debouncing buttons). I would guess one of the problem will be waterproofing it and making it reliable. It will always be a risk doing an ironman with it…
The thing about the Arduino is that it also looks like it can be used to sniff out canbus signals. Quite a few people have done work on that in the context of cars and there is an open source project out there to make it easier. So, version 2 would be to try to get the Arduino to decode the shifters and then pretend to be them. Not sure whether that is possible yet though but from what I have read it would seem like it is possible. The Arduino forums are a great source of info for this sort of thing.
Out of interest, it seems you can link an Arduino to an ANT/ANT+ module. This, linked to your powermeter and cadence, could get you a fully automatic gearbox. I am sure it would be a completely useless but it couyld be fun trying…
Dont worry about breaking anything as long as you take your time. The modules will pop right out after you remove the torx screws.
I did look into the automotive canbus systems which do seem to have signal cloning capabilities. The down side is that they are 3 wire shielded systems. From some of the diagrams, the third looks to be a ground but Im not too sure yet. I did order a canbus signal analyzer and software that can interpret the signals as an input. The easy part will be getting the signal…the tough part will be finding a way to clone it. Either way, the first step seems to be interpreting the signal which will be done soon hopefully.
As you can see, all sorts of fun can be had with di2. What type of switches did you end up going with?
I know some stuff about CAN which might help. The auto industry uses differential (2-wires) CAN-bus because they have all kinds of electronics and have to be robust against noise. Since there are almost no electronics (compared to a car) on a bike I would think that the 3 wires are just Ground, Vcc & CAN-signal. After all the ECU in the STIs also need power so I would expect them to get the Vcc & Ground from the battery. Then the Signal is just single wired which should be plenty. Especially since there is no need for a high data rate. That’s all just my guesses but I’d be very curious what’s the setup. (my guess is 125 Kbit)
To generate the signals all you need is a uC with a CAN controller. They’re super cheap and nowadays there are tons of uC that have one already integrated. I think the Arduino doesn’t have any but for such an easy setup with just 1-2 messages you can hook up a controller over SPI or whatnot. I think there are also some projects that already have realized Arduino+CAN.
Hello, the DA di2 barend shifters are just momentary switches so those could be used with the module from the ultegra shifters. You will need to use the housing and switches, not just the housing though.
You will need the Ultegra STIs (one set) and the cable that connects the two (called handlebar harness) as well as some type of momentary switch for shifiting. You can use the DA di2 shifters as the momentary switches but you will still need the parts from the Ultegra STIs. Sorry, its a little confusing at first.
For shifting on the base bar, you can use any type of momentary switch also, even the DA brake/shifters…just wire them to the module the same way as the bar end shifters.
Electronic Kit Ultegra (FD, RD, Shifters, junction boxes, battery, battery mount, harnesses).
DA Di2 TT Shifter (or the much much cheaper cateye buttons)
DA Di2 TT Levers (or any momentary buttons, most of which can be much cheaper.)
Handlebar harness
The question is whether all that ends up any cheaper than just buying the DA Di2 mechs and cables instead of the Ultegra.
It should. My project cost me about $1000 all together including switches and a LiPo battery. Even if one where to use the DA shifters and brake levers, it will still be cheaper…just not as cheap.
Styrrell has it correct. Though the only harness you really need is the handle bar harness since it has the adjustment button and battery level monitor. You can make the rest of the harness and the junction box and save about $100 if you are comfortable with your soldering skills. Like he said, any momentary button (push, tactile, lever, toggle…whatever) can be used to trigger the shifting. But if you dont mind the cost of the DA shifters and levers, you can wire those in in place of the momentaries. Let me know if youd like to see a wiring diagram of how I ended up doing things. If theres interest, I can post it/send it.
A wiring diagram would be great. I dont know the buttons youve mentioned because I`m from Germany, maybe it is possible to send me any links of those buttons.
Since you are answering questions, and I have not seen this clearly in the thread, how did you manage the brake levers? It is not clear if
you deployed satellite shifters or not on the brakes. If so, could you post pics and provide a bit more detail? From the talk about simple
surface mount, it seems one could splice a shifter switch onto any pursuit/brake combo , such as my Vision setup.
Yes, I have the vision levers also and mounted the switches on top and on the side ( so that the thumb can trigger down, finger trigger up). The good thing about these switches is that they are surface mount and small…and can be put any where youre willing to run them. I will take pictures and post soon.
