I have a new (Dura Ace) chain. I have some pins. I have a chain-tool connected to a multi-tool.
There are >2200 miles on my current SRAM chain. I know it is stretched. I would like to replace the chain myself. I have considered buying a dedicated chain-tool for this task.
I have had previous chains replaced (at the LBS), so this will be my first attempt at replacing/installing a Shimano chain.
My current Ultegra cassette has been used for about 8000miles. I have considered purchasing a new cassette, but it LOOKS fine.
I am seeking advice on how to proceed.
These are my main questions:
Should I go ahead and get the dedicated chain tool? If so, which type is best?
Should I get a new cassette - if so, which type is best for 9speed - SRAM or Shimano?
You can use the chain tool on your multi-tool without a problem, assuming it’ll fit a narrow 10spd link, which it should.
Wow, 8,000 miles on a cassette. I say try it, and if you notice the chain jumping or skipping then replace it. I can’t tell you the difference between SRAM and DuraAce, sorry. I’ve used 105 cassettes.
Think about installing a Wipperman link on the chain. I have one on my 9spd chain and love it.
Bear in mind this is just one opinion, and I’m sure there are as many as exist multitools and cassettes.
The multitool you have will probably work for what you need to do, however, it is possible that it is too compact to be able to start the shimano pin into the chain… I would back the screw out almost as far as it goes, and see if the chain plus entire pin will fit. The chain should rest against the far side of the tool away from the screw mechanism. I have found that a dedicated tool (I prefer the Park) is just easier to use on all fronts.
As for cassettes, I would get whatever your LBS has in stock in the size/quality level you are looking for at a good price. Consider weight etc… Shimano and SRAM chains are compatible, although I suspect that some will claim to get better shifting with Shimano on Shimano etc… My road bike has a Shimano and my Tri bike has a SRAM cassette. I would also consider not getting Dura-Ace as they are light, but also won’t last as long–save that for the race wheels. I run a 105 cassette on my road bike, and it has lasted a long time, shifts adequately, and was significantly cheaper.
The park website has a good section on bike repair, so I’d take a look there for pictures, etc… If you muck it up, and really damage the chain (far from likely) the worst thing you will have to do is buy a new one and pay LBS to install. If you are really not confident, I would take your bike in and ask the mechanic to show you how to do it, so you know for when you are on the road with a broken chain! It’s not that complex, but requires a little finesse. Good luck
