do all disks flex enough to hit brakes? or just the renn 575?
thoughts?
i open my brakes all the way and still hit sometimes
thoughts?
Honestly, I don’t have the problem with my 575. I’m 200lbs and mostly a crit rider so I know how do wail on a bike during a sprint. In all my TT’s, it’s not part of my gameplan to sprint of the side of the bike to get it to flex. Big sprints in a TT will burn “matches” like they’re going out of style. I can stay in the saddle and motor which has no flex issues at all - E
Several of the cheaper discs flex.
Most discs however, are significantly stiffer than normal wheels and can lead to cornering issues and general discomfort.
Newer Zipps will have lateral movement in the 3-3.5mm range, older heavier models more like 2mm. I believe the Renn is more like 5mm, more or less equivalent to the Aerospoke.
Chris
I’ve had a zipp disc and now have a renn 575. Both flex enough to hit the brakes, but for the renn I have to open up my brakes because it’s so bad.
“zipp disc and now have a renn 575. Both flex enough to hit the brakes”
Yet another advantage to a $65. disc cover.![]()
I had a 575 that flexed pretty much anytime I was out of the saddle. I always rode my brakes open in the rear with the disc. My new Zipp doesn’t seem to do it on the rides around the neighborhood, but I can’t say 100% since I haven’t raced it yet.
Hey Cerveloguy, a $65 disk cover is just no good so stop trying to flog them. It may provide the aero benefits and no flex if it is on a good wheel but can you imagine the outburst from the ST crowd if you were to post a pick of a new Felt DA or Guru like Tom D did last week with a Mavic Open Pro and cheap wheel cover on it instead of the bling bling Zipps … and had the audacity to call it bike porn ![]()
Hehehehe. So true.
can’t you just take off the wheel and have any wrench at your local LBS true the wheel?* ***
No:
a) it’s a disk, you can’t true it
b) it’s already true
c) it’s flexing, discs don’t have the lateral stiffness of spoked wheels, probably particularly true for flat discs like the renn
Open the rear brake wider
It’s a race, you don’t want to use the brakes.
Seriously - mine’s so slack it has practically no braking effect whatsoever.
And yes, some discs flex more than others. I can feel a diffrence between my X-treme and my Mavic
no flexing on my 2003ish Zipp disk, damn thing is so stiff it skips around hard corners…
My old Falconsports disk was super duper flexy!
if you just look at the design of a disk and think of the forces on it it’s pretty amazing how stiff they are for the weight…
Also a bit of flex can also make a disk a LOT easier to get used to in the handling department, especially in tight corners where the deflection of the disk actually helps it to track and maintain traction better than a super stiff disk (in my opinion at least)
The solution is to have a sexy 85-100mm carbon rear wheel with a disk cover,and remove the disk cover for the pictures.
(An other benefit in this case is that the disk cover is much lighter since the outher 6cm edge is removed. My “disk” (Beyondprod 85mm wheel + CH aero cover) has a total weight of 1200gram, about the same as the other lenticular disks (Hed and Mavic).
