You always get what you pay for…
Not true in the case of a wheel cover. We know that it works as well or better than regular disc wheels.
Thats only my opinion. Also some call Olive Garden a fine Italian cuisine ![]()
“If it was me, I’d buy a new disc…Adding a pound to the rear wheel even on a flat course sounds like a bad move to me.”
Hey, it’s your money, but understand the difference between weight and aerodynamics. Weight doesn’t begin to trump aero until a gradient of 8% or so. A dedicated disc is no faster than the 808 with cover and both are faster than the 808 by itself.
‘’ How about covering the vents of your helmet with duct tape?‘’
That depends. Do you use a pound of duct tape?
No, I use carbon duct tape that’s $50/inch.
“That depends. Do you use a pound of duct tape?”
must be a very big head
dirt
I think it’s a serious mistake to take a great wheel like the 808 and slap on a one pound piece of cheap plastic and say that that is an improvement. Zipp claims that the 808 is the closest thing to a disc. It’s very aero, light weight, and responsive. Adding a pound to the rear wheel even on a flat course sounds like a bad move to me. I know that here on Slowtwitch the thought is that weight doesn’t matter, but it seems that everywhere else in the cycling world weight is crucial.
If it was me, I’d buy a new disc. Of the three choices you gave I’d stick with your 808’s.
A cover trimmed for an 808 doesn’t weigh a pound.
As for whether or not it’s a mistake to use a cover on an 808…don’t knock it unless you’ve got the numbers to back it up.
Knowing how Jens operates, there’s a reason he mostly uses his 808 with a cover instead of either his Lightweight or Comete discs, and I don’t think it’s just so he can use his PT hub…![]()
‘‘I use carbon duct tape that’s $50/inch.’’
I’m so tired of the black carbon duct tape, I’m waiting for the new painted stuff!
Perhaps personal preference or confidence?
Without a PT build into the Comete or Lightweight, it’s damn near impossible to quantify which is faster. Granted, you could run an SRM or iBike to tell you, but then you’d have to use it on the 808 as well…can’t change variables like tolerance of the machine.
Jens owns an SRM as well…he’s got all the toys ![]()
Believe me, his “personal preference or confidence” is going to be based on measurements.
Well this discussion is interesting probably more so if I knew who the H&ll Jens was
I’m shocked, I tell you…simply shocked!
Do a search on the slowtwitch username “jens”…![]()
Other than being custom cut for a power tap, any one have any idea of the performance differences between this cover:
and the regular ch aero one?
This seems to resemble the shape of the zipp clincher disc.
The main difference is the wheelbuilder.com sticker. Which is good for at least 3w savings. ![]()
Since it IS a CH Aero cover that they sell.
The outer edge of the wheelbuilder supplied cover is also trimmed to best fit the particular rim you have. The “stock” CHAero cover only fits best on a low profile rim.
Some would argue that the cover combined with the Zipp 404/808 “bulge” makes for a fast combo.
“This seems to resemble the shape of the zipp clincher disc”
If there was a side profile photo you’d be able to see a lenticular rather than flat shape.
It actually is just a CH Aero cover, just custom cut to fit a Zipp wheel. Anybody could do the same thing if they’re careful enough, but when I tried it to fit a Hed Jet 60 my job wasn’t as neat. For the $25 surcharge, I’ll get wheelbuilder to do it for me next time.
Hell, it took me a while to figure out who I am. My mother still keeps a little stick figure drawing I made when I was 5. It says on it: “I’m me and that’s no joke.”
In any case, I did do a number of same-day tests with an SRM and the “bump disk” was consistently faster. Testing in real-world wind throws some doubt on it. But it was pretty consistent.
To doubters, I would ask: why do you think both Hed and Zipp are making bump disks now?
