I currently am looking into getting a disc, but it unfortunately appears that I cannot get a wheel cover from wheelbuilder, as they state the chainstays are too tight.
I’m assuming the problem is not at the rim, but rather at the hub. I would venture to guess that the thickness of the disc cover on top of an already tight tolerance wheel just won’t clear the stays nearest to the rear dropouts, which run quite close near the hub. I am not sure the hub width on a lenticular Hed disc and whether it would be an issue, but I believe I’ve seen some Hed pro athletes like Paul Amey run a Hed disc on a transition. A flat Zipp disc (absent the lenticular design) won’t be a problem at all, though. The other option is to find/build a wheel with narrower (and lower) hub flanges on the nondriveside that would provide the clearance.
The only reason for this post was because of your sig:
Always use a rear disc. Unless it kills you, it makes you faster.
Mott 2:1
well you already have an H3 on there which is damn near as good as a disc
Here’s my bike:
I ran an 808 with Wheelbuilder cover with no problem and currently run a Zipp clincher disk with no issues. I ran a sub9 and it was fine after I adjusted the rear brake calipers
The problem with the NDS chainstay and the covers is that the covers tend to have more of a “dish” than the underlying wheel and they don’t sit right down on the spokes. Mine would *just *barely clear, but would actually start rubbing if the NDS was left in the sun for a few minutes! Yup, from the plastic exanding. The “tight spot” is near the hub, not near the wheel or any “wheel bulge”. The bare wheel without the cover clears this area with plenty of room…but, once you put the cover on, all bets are off.
So…how did I solve the problem (without resorting to a “true” disc?) With the strategic placement of some double-sided tape, of course
Seriously, I placed some double-sided tape on the inside of the cover at ~ the radius I wanted to “pull in” towards the spokes. One nice thing about the bladed spokes under there is that they have a good amount of surface area for the tape to stick to. The cover ends up not quite as smooth as original (since the extra material has to go somewhere) but it’s not horrible. I put that in near the end of last week and have ridden with it a few times and it appears to be stable. I’ll see how it goes through some additional temperature swings as things eventually warm up more around here…
I ran a 2008 808 with a wheel cover. I had an american classic hub, so I used sand paper to open the center hole to get the cover to lay flatter against the spokes and I had no issue with rubbing.
I have a pretty standard 32 spoke training wheel with PT Pro+ hub and wheelbuilder cover, and it fits in my Transition. There is only approx 1mm of clearance near to the hub on the NDS, but I’ve ridden with it for perhaps 20 miles now, and haven’t noticed any rubbing. It might depend just how big they cut the central hole on that side for the PT hub, so if someone has one that rubs, enlarging the hole might fix it.
I also have a Jet Disc that I’ll be switching to when my Cinqo eventually arrives, and that has even more clearance. It’s the C2 version, but a recent one where they told me they had slimmed down the carbon structure compared to pre-Oct 2009 examples.
The hub makes a huge difference. I have a Hed Jet 6 that I have to slide out a bit to avoid having the spokes rub the NDS chainstay. I also have a Powertap wheel with ample clearance. Because of the dome that covers the battery area, the PT hub places the NDS spokes nearer the midline of the wheel. At the point where the spokes rub, the PT wheel is roughly 10mm narrower, all on the ND side.
Does radial vs cross laced make a difference on the NDS clearance?
It wasn’t so much the spokes under the cover as it was the fact that the cover doesn’t draw flush to the spokes. Once the cover was “pulled in” by the double-sided tape, there was tons of room. Despite the fact that the radial NDS spokes on my wheel are “heads out” and a cross laced wheel would have half the spokes laced “heads in”, I don’t think that would be the issue.
