“can’t believe i need to explain this” and “most triathletes are just TTers with commitment issues”
you have a natural tendency toward troll-type speech, but i’ll ignore that for the purposes of the discussion.
yeah, the culprit tests make discs look pretty bad. but i’d like to see what others, who are invested in the process of making very good aero road bikes, and equally good disc brake road bikes, have to say. i wrote all the usual suspects about this. i wrote them because it seems to me that you can’t be heavily invested in road disc bike manufacture (as specialized and others are) without addressing the aero detriment of these bikes. you have to find a way to speed them back up.
what i’m hearing from these engineers, notwithstanding bikerumor’s article, is that the detriment isn’t as great as i thought it was. and this is before you do anything available to you as a bike designer when you don’t have to engineer the bike and the wheels around rim braking.
you might, in the end, be right. but the culprit test was a bike that could accept anything: bolt on rim or disc brakes. shim this, space that, it goes from 135mm to 130mm. this might or might not be a valid way to test a bike designed, from the get-go, as a disc brake bike.
I thought that was a compliment, after all, y’all’s talk about bikes more than anything else on this forum.
You say that industry experts are saying it’s not that bad, yet they haven’t even tested it. Until last year everyone thought shaving your legs had zero aero benefit, and then boom! So yeah, conjecture isn’t the way to go on this.
Sure, the spacing could have been an issue, but are any wheel manufacturers really going to go with a new standard when so many have already been tried just to appease a niche market?
“Maybe I was a hasty in assuming the terrible bike handling thing was isolated…”
i can only assume that you only ride flat TTs. for flat TTS, no problem. no need. but triathletes (who are, what did you say, TTers with commitment problems?) are often riding timed races on road race courses. it is not at all uncommon for a triathlete to face a 45mph or 50mph descent, with turns.
no one who rides courses like this downplay the quality of a bike’s handling or braking. but if you don’t ride courses like this, then, you aren’t a target of these sorts of handling imperatives.
I ride everything from 10 mile to 12 hour TT’s on all types of roads. Hitting 50+ happens depending on the course, and quite often on training rides, and it’s not really a big deal. I wouldn’t even classify myself as a great bike handler. Truth be told I’m about as mediocre as it gets.
The aero hit on upturned base bars is real. Less than 5 degrees of tilt cost me 5.5w on flat extensions…
