I just think the disc brakes look cool.
Still hoping someone like cervelo will come out with them on a TT frame
It seems that Cervélo are reasonably committed to hydraulic rim brakes with their Magura tie-up.
On the subject of Magura I had their HS33 hydraulic rim brakes on a commuter bike here in Germany, and they are absolutely bloody awesome.
Yep, that is what I am assuming I will get.
The area-impact (I would assume) would not come as much from the brake-disc itself (it’s going to be 140mm disc in the back and 160 in the front at max) and the frontal-profile is very minimal.
Bad assumption. The majority of the drag IS from the disc itself, along with the necessary hub structures to mount the disc and the additional spokes required (for an equivalent strength wheel) to handle the braking loads. Sure, that’s not necessarily a large hit at zero yaw, but that disc quickly comes into play once any yaw angle is experienced.
One thing the Specialized test didn’t include is power-to-rotate, which will be slightly higher just due to the additional spokes alone.
That commuter has the largest hydraulically actuated disc brake you can fit in the bike! ![]()
the new hydraulic road brakes are nice, in the past the BB7 mechanical had a tendency to drag a little on one side. They work fine on a road bike, the wheel changes seem a bit slower but maybe it’s just a need for practice. If one were using disc on the cross bike, it would be nice to have the same setup on the road bike so the equipment could be shared.
Electric shifting and disc road brakes will be the standard in a couple years, over this season they are getting sorted out in cyclocross and will be a much more mature road technology come spring.
Is it this huge improvement? No, neither is electric shifting. Since the advent of clipless pedals and STI shift levers, there have not been any real significant “must have” changes in road bikes, despite the price of a new bike tripling.
I should know better then to assume ![]()
Although that I agree that the disc at 0-degree will hardly have any aero-impact. I would think that the difference between upstream from the appearant wind (ie wind from the left) and downstream from the appearant wind is where there are differences. But most of these would not need to come from the rotor itself, but more likelly from the increase in spokes with the wind-facing side being the worst. The increased hub-diamter would be non-impacting since it sits inside the spokes and that is a very turbulent area. The rotor-mounting structure (Shimano or 6-bolt) is completely covered by the disc-rotor and probably has biggest impact at zero-yaw (which I would think is minimal). The biggest impact could be the point-of-pressure which most likely shifts due to the disc. If only we would find a drag-chart that compares the Zipp 303-FC-CC and the 303-FC-CC-Disc
The ZIPP 303-disc set weighs in at 1660gr by the way, heavier then the DT-Swiss MTB 29" wheels, defenitly more aero though…). Probably some low-hanging-in-house-fruit between Zipp and DT-Swiss right there.
On your comment regarding power-to-rotate, also here, I would think this is not so much caused by the disc-rotor itself (decent alu-spider 140mm discs weigh <100gr) but come from the added weight due to increased spoke-count, disc-specific lacing and hub-strengthening. I don’t know the weight from the top of my head, but competition-level carbon-rim 29" MTB-XC wheels come at around 1450-1500gr/set which is pretty darn light given the abuse they have to tolerate.
S.
Power-to-rotate at a constant speed isn’t a function of weight.
Disc brakes are less aero
Disc brakes are not legal for road racing. Not sure about triathlon but no one makes TT disc brakes, possibly because #1?
refer to #1 & #2
I’ve seen a test in a german bike magazine in which layers
of some disks were melted, when in a descent and when the person
is not a lightweight.
The biggest problem though seems to be a sudden loss of brake power
when on a long descent and when the person
I do not know if these problems have already been solved, but it
seems that the system is not yet matured for racing bikes.
I wonder, could a road bike with mechanical disc brakes be upgraded later to a hydraulic system?
It appears the new disc-equipped Roubaix models are now using hydraulics (and now also come in 11-speed versions).
**Is it this huge improvement? No, neither is electric shifting. Since the advent of clipless pedals and STI shift levers, there have not been any real significant “must have” changes in road bikes, despite the price of a new bike tripling. **
Agreed.
I’ve ridden some of the new mechanical disc braked road bikes. There is a difference in the feel. However, I really could not say there was a huge difference between that, and a well set up set of Ultegra quality or better, rim caliper brakes. I’ve ridden the latter in all manner of conditions and terrain, and never had a problem. I’ve never said, “Wow, if I only had better brakes”.
Yes, should be no problem upgrading down the road except for maybe minor cable/hose routing issues.
I’ve just put the new Sram Red hydraulic discs on my bike and so far they’re great. I’ve used the BB7 brakes for a few years and these new ones are way nicer to use.
for cyclocross i imagine the discs would be nice. In muddy conditions, the amount of metal that gets worm off the rims is pretty remarkable, plus the braking is just dreadful after a while. This is one season of cross
Yes - this is the one application where I can see real advantages. I was talking about road use.
For CX the two chief advantages would be as you noted, less wear and tear of the rims ( but some of this would be transferred to the rotors!), as well as better clearance in areas on the bike that in REALLY muddy conditions, clearance can be an issue.
Same experience here. I’m not at all opposed to owning a bike with disc brakes except for the one troubling mention by here about how easy it is to lock the wheels. As if that were some sort of virtue. I don’t want to lock up my wheels. I don’t want it to be too easy, either. I don’t want to have to learn and automatically remember to have some soft touch. Next thing you know we’ll need to add ABS systems to our disk brakes
Yes, but how cleanly that is done depends on the cable housing stops vs cable housing guides (for full run housing). I make all my disc-brake equipped frames with open cable guides for that very reason.
Agreed.
I guess you have been lucky. I have gotten caught a few times in the mountains when started to rain. I basically lost my brakes on the downhills!
I then blew off a tire at IMLT in the hills I assume from too much braking, and heating up the rims.
So I really could care less about the weight and aero stuff, just seems they are more safe which is why I would really really consider a set on a new TT bike.
and yet people have been riding disc brakes on mountain bikes for years, in conditions where traction is much more limited than on the road.
Agreed.
I thought your primay goal was to go against the ST wisdom?
