Difference between "English" and "Italian" in crankset terminology
Can someone please enlighten me - what is the difference between “English” and “Italian” when it comes to cranksets?
The threads are a different size.
Cranksets are the same. The difference is the bottom bracket shell on the frame. English bottom bracket shells require English bottom brackets; and Italian, same.
Ah I see. So if I were to purchase an Italian threaded crankset, but my BB is English, they wouldn’t work, right? Then I’d need to buy a new Italian BB to go with the Italian threaded crankset… correct?
Your frame itself (or specifically, the direction of the BB threads and with of the BB housing) is what determines which type of BB to use. English (practically universal now) has left (reverse) threads on the non-drive side, and the shell width is 68 or 73 mm. Italian has conventional (right) threads on the non-drive side (which makes it try to unscrew itself) and 70mm shell width.
So if your bike currently has an English bottom bracket, you can only replace it with another English bottom bracket with the same shell width.
I think the last post has the threading backwards. I just pulled and greased my BB a few hours ago and the NON-drive side has normal threading, drive side is opposite threading. I typically just remember that they’re opposite of the pedal threading on a particular side.
Crap, you’re right - I was thinking of pedal threading. Doesn’t help that I’m already several beers into tomorrow’s day off.
Which raises an interesting question - why is it that beer and wrenching seem to go together so well, but beer, wrenching, and the internet don’t?
I thought it was beer and wenching that went together particularly well. Beer and wrenching goes together inversely to the cost of the item being wrenched.
Just so you know, most “Itialian” frames now come with Englist thrds. In the old days, Itl thding was great, because you could take two adj. cups and micro adjust the chainline when necessary.
Steve
SMp
P.S. dont forget about fr. thd 35 x1, or the even more obscure Swiss thding
Individual results may vary. I’ve actually rewired rooms in my house (successfully, I might add) and had no memory of it afterward.
Sometimes Dutch courage is useful when you’re tackling an intimidating project - like, say, swapping out a BB for the first time. Also is nice for reducing the tedium of boring projects (e.g. thorough cleaning of drive train). I wouldn’t recommend it for installing trainer tires to anybody who is an angry drunk, though.
My Belgian made road frame is Eyetalian. But you are correct, in this age of carbon ubiquity, the Italian BB shell is almost a thing of the past.
You have to pay the “vig” to get one of them to accept the bottom bracket :wink:
From what I’ve heard the difference between English and Italian is the way they screw. But I could be wrong.
…and also in the way they cook…
And the differences in spindle length.
I recently purchased a 2008 QR Lucero - how would I tell if this has english threading?
It’s English - click on “specifications.”
http://www.racycles.com/triathlon/triathlon-framesets/quintana-roo/quintana-roo-lucero-lite-2008-frameset.aspx
