I am looking at purchasing a Zipp front 808 Clincher. It is between a 2008 wheel or a 2009. Both brand new but the 2008 is $200 cheaper. Is it worth it?
The hubs changed a bit from 2008 to 2009. Same rim though.
zipp made their hubs a little lighter in 09 and
I believe that they also changed the dimensions so the wheel can be built stiffer. That said, it’s a front hub and if you are going to use it for triathlon the 08 is by far the better buy.If you are worried about I think you can probably find an 09 zipp hub brand new for less than that.
Not likely. The 88 hub (the 09 front hub) is $390 MSRP. It’s quite a substantial upgrade from the 82 to 88 hub. Not sure if it’s “worth it” to someone, but the 88 hub does represent a marked improvement. I’ve ridden both, and the 88/188 hubs offer a noticeable improvement. I would say the 88/188 laced 808 clinchers I have are the nicest all around wheelset I’ve ever used. Were I to have only one wheelset for all of my riding, that’d be it. Of course, I have a 404 laced to an 82 front hub that is still working well with about 8,000 miles or so on it, so the old hub is still a great hub.
Since you ride the clincher version, do you think the Zipp 808 clincher is less aerodynamic than the tubular version? I ask this because the HED web site shows clinchers to have higher drag than tubulars, both HED and Zipp wheels. If true then that would offset the rolling resistance advantage of clinchers over tubulars to some degree. But I’ve never noticed anything on the Zipp web site discussing this. So I wonder.
Yes, clinchers are less aerodynamic. Theoretically this could offset some of the difference between a well glued tubular and a clincher in terms of Crr. BUT, that implies a proper gluing job, appropriate tire selection, etc. Also, with the newer - wider - bulges on the Zipp wheels, it’s not a substantial difference, especially if you are running wider tires. The bigger bulges are more forgiving of tire selection. I think the reason that Zipp doesn’t post this is that it is hugely dependent on tire selection. For example, if you use the Bontrager aero wing tire - which fills in the gap between the tire and the rim, that could actually be even MORE aerodynamic than a tubular. Or the Zipp tire, which was designed to improve total airflow. I don’t see it as a reason to choose wheels, so in that sense, I think they don’t want to be misleading. But, yes, in general, tubulars are slightly more aerodynamic.
