Did I read this wrong or
did I understand it wrong or is there an error in the JC article on water bottle aerodynamics? He says at 30 miles an hour there is a resitive force of 7.5 lbs, which means “that every exposed square inch of surface of bike and rider has a force of 7.5 lbs to overcome at this speed”
I believe 7.5 lbs is the total aerodynamic force on the rider and not the force per square inch. 7.5 lbs at 44 ft/sec (30mph) is 330 ft-lb/sec or almost 450 watts, a reasonable power to overcome 30 mph headwinds. The typical rider probably has an effective frontal area of well over 100 square inches which would require a power output of 45KW to attain 30 mph if it were 7.5 lbs/sq-in force.
It is a small point of correctness as it doesn’t effect the overall data collection or assumptions that can be drawn from the study but has been bothering me all day.
It has to be an error…it sat sideways in my gullet, too. Still, as you said, it doesn’t affect the results, it’s just a mis-statement. If I didn’t know something about the history of person writing about these results, this mis-statement would immediately make me question the results. But, in this case, I just overlook it as a simple error. I know of no one that is immune from this disease.
