auto208562,
Yes.
As I understand your question, nothing seems out of order to me. You will almost never have as sure braking on the hoods or feel as stable braking as you will braking in the drops.
In general, when descending and braking, you are trying to slow your bike down, but the only thing slowing your body down is your ability to keep yourself with your bike. The laws of physics are trying to keep your body moving at the speed of your bike before you applied the brakes. Only your grip on your bike is keeping you from separating from your bike and continuing down the descent ahead of your bike. When you are on the hoods, you have a very high center of gravity that is usually above your hoods.
As your bike slows, the natural tendency is for you body to continue forward over the top of your bike. In part, your grip on the hoods is slowing/keeping your upper body from moving forward over the top of your bike and on down the road ahead of your bike.
At the same time you are trying to keep your upper body on top/behind your bike as you descend, you are trying to pull your brake lever back towards your body. This motion is a contrary motion to trying to maintain your grip on the hoods. In addition, as you pull the lever back towards yourself, this motion complements the forces that are trying to move your body forward over the top of your bike as you begin to slow down. Almost like a tuck and roll motion only it is your hands that are tucking and your body that wants to roll over your hands.
I never feel as confident descending on the hoods as descending in the drops, for multiple reasons.
One, descending in the drops lowers one’s center of gravity. Now the handlebars are generally right in the middle of your center of gravity for forward motion.
Two, now you have something to push against, your handlebar, to keep you from going forward over the top of your bike.
Three, you now have a lever, the handlebar, to pull against as you pull the brake lever back to begin slowing your bike. This time, this motion is not complementary to the motion that is trying to separate you from your bike as your bike slows down.
Four, getting in the drops is almost as aerodynamic as being on your aerobars. This will enable you to descend faster. Granted, one of the other ways to help slow yourself down is to sit up to catch more air and this postion usually places one on the hoods.
In general, when descending, it is recommended that one get in the drops if the descent requires braking or is technical in terms of difficulty. There are two primary reasons for this. One is lowering your center of gravity which greatly reduces the likelihood that you will endo (do an end over your bike) as or if you need to brake. And two, in the drops you have better and more sure control of your bike to manage a technical descent.
