Yes, I have 2 implants.
My own background: crashed bike at age 7, cracked my 2 front teeth. Long story short, at age 34 through 36, I had 2 implants. I say that because it was a 2 year process of reconstructive surgery, etc.
The real decider for you will probably be your employment benefits vs. your independent wealth. Implants are very, very expensive. Chances are that your work will cover bridges, but not implants. Having said that, I’ll describe implants a bit below.
Now, if your bone is healthy, and you have no infections, you will be in a much better starting point than I was. (I had 25 years of undetected bone infection to deal with). They will drill a hole in your skull, and place a female threaded titanium insert. It will have a “healing abutment” cap placed in it, to stretch the gums so that the eventual crown can slip under the gums like a real tooth and give you a realistic gumline. You will not have a tooth for up to a year after that surgery - it will take that long for the bone at the surgery site to grow back and ‘invade’ the titanium insert, making it a permanent part of your skull. Eventually, a post will be threaded into that insert, and a crown placed on top of it. For the “up to a year” that it will take to heal in place before getting the crown, you’ll need to have a partial denture - kind of like a retainer with a false tooth on it.
In fact, you have 3 options, in ascending cost:
-partial denture
-bridge
-implant
Your chance for a bridge may be reduced if the tooth next to it with a filling is exceptionally bad - they need to grind the adjacent teeth down to posts when making a bridge - if the adjacent teeth are bad, that option is eliminated.
I like my implants, but have had no other dental issues. They feel good, and I’m able to floss normally. Plus they keep the gums stimulated, so there is no recession there either.
I had an oral surgeon, not a dentist, do my work. It was tricky stuff and a specialist was required. Also, since he is a doctor, not a dentist, this was “medicine”, not “dentistry”, and that makes a difference for some insurance policies or in my case (as a Canadian) Medicare coverage. So, you’ll want to look into that too.
Hope this helps a bit.
Marlon
