Marginally faster than a Shiv which is ~ Old P3 at low yaw.
I thought it was Transition ~ P3C. It’s safe to assume SHIV > Transition.
The data suggests Transition ~ Shiv at the most common yaw angles.
To the OP, have you tested this position?
I’m sure he did. I remember seeing Wind Tunnel pics at some point.
#stalker
To the OP, have you tested this position? I note that your chest is almost downsloping, and you are possibly showing more back to the wind than necessary. Steve hed used to say he aimed for a chest angle close to about 5 degrees above horizontal and that a flat chest was too low usually.
so, you may be too low.
second, your body type is likely an outlier. I mean, you have an adjustable stem on what is one of the longest/lowest bikes.
Third, I think faster bikes than your alloy p3 but close in geometry are the shiv tt, felt da, or qr cd.01. Or you can sit around waiting for another swing in geometry trends which may never come…
The position was optimized during a wind tunnel session without an aero front wheel and a much less aero frame with a CdA of 0.257 w/ tare. Looking at some files from races my current CdA is 0.235-0.240 with full gear. Switching to a faster frame will drop me to ~0.225.
I noticed a few things in your position which lead to the requirement of super long and low (Trek’s older OCLV frames were notoriously long and low 56 TT + 51ST c-c, but not super bike today).
Re 1 and 2, we are all built a bit differently, nothing one can do. Re 3, have you tried sliding back a bit? Your hip angle is amply open. Re 4, this may be less aero than a flat back. In other words, your elbows may get a bit higher without becoming less aero.
Of course this is all speculation from looking at a single picture. Purely for your reference.
My power really suffers if I close the hip angle anymore.
that bike is too small/short for him.
if he had a bigger size he’d be less egg-shaped and more able to disappear behind shrugged shoulders/head
so basically, I agree with you
There’s been a convergence in the bike industry to Trek’s middle of the road geometry. I can’t say I blame the industry for moving towards that direction, but I believe the trend is preventing us from achieving faster, more aero positions.
My position, which doesn’t seem extreme by any means, cannot be replicated on a single super bike due to the lack of reach, excess stack, and lack of extension tilt.
My only option for a faster frame is picking up a used P4, which is still a bit of compromise with the rear braking and wheel with limitations.
How do you guys feel about bike geometry? What would you like to see in the future?
The bike companies like auto companies have to make money, not cater to race car drivers. The bulk of the market needs a moderate performance Jetta/Golf not a high end Porsche or an F1 V12. Just size down and use a long stem and let the bike companies service the bulk of the market!
Just out of interest, which bikes do you consider in the bracket of ‘superbikes’ ?
That’s actually really interesting. Do you have the data that supports this and would you mind sharing?
thanks.
^ First you post this
^ Then you post this.
The two don’t match. This is an aggressive position. It might be your fastest and most comfortable - I’m no aerodynamicist and no fitter - but it’s definitely an outlier.
Plus, even if it was tested fast, there might be a position that’s as fast that doesn’t involve turning you into the hunchback of Notre Dame…
Just a few posts up, he talks about the testing he’s done in the wind tunnel.
I don’t think the word “aggressive” means what you think it means. There is nothing aggressive about what he’s doing there. He’s just sitting there. Passively even.
if you ever do become one, or even visit one, please please don’t use nor encourage the use of the word “aggressive”
I don’t think his position is an outlier. Average Cat3/2/1 time trial position. Shoulders aren’t even with hips like Zabriskie or anything.
Or that his hunchback is necessarily bad. Looks like an airfoil with an aero helmet on I bet. See: Tony Martin
Most triathletes just don’t take position very seriously. Too much whining about comfort and power without trying to get low, powerful, and comfortable.
I, like a previous poster, would be interested in arm pad stack and reach.
Pad stack (including Ceegee pads): 545mm
Pad reach (where elbows would touch): 545mm
Funny how that worked out.
If you could somehow get hold of an X-Lo Aduro, a 51cm P5 would work. You would have to modify the Aduro to make it safe but that is pretty easy.
Pad stack: 545mm
if you ever do become one, or even visit one,** please please don’t use nor encourage the use of the word “aggressive”**
X 100000
he rides a saddle designed for rotating pelvis on the nose and does not rotate pelvis. if he did rotate pelvis, he might need a longer reach
should post pad stack/reach numbers if he wants input
It’s still a bit too tall/narrow.
Cervelo measures their stack/reach without the cushions and middle of the arm rest cup.
I don’t think the word “aggressive” means what you think it means. There is nothing aggressive about what he’s doing there. He’s just sitting there. ** Passively even.**
This. The position is very comfortable.
For the other comments about the back shape, I’d be classified under John Cobb’s “B” styled back.
Fairly similar to Tom A’s position in terms of drop, torso angle, extension angle, except his saddle is pushed further back.
