Dealing with Exercised induced Asthma?
Folks,
One of the gals I train with has developed a severe case of exercised induced asthma that her docs have concluded is being triggered by our very high mold counts this summer…
She “discovered” this after DNF-ing the swim at BLST and asking to be pulled from the water. When she got home they did the full battery of tests including a cardiac scan that showed her heart in fantastic condition. The docs eventually concluded that it is EIA and gave her an albuterol inhaler…
My question is: has anyone heard of a more effective way to manage EIA when considering participation in IM distance racing? As background she is over 50, a moderate swimmer, solid biker (around 18-ish for IM) and a damn good runner (has potential to go sub 4 in IM - Multiple time Boston Qualifier) and she is scheduled to do Louisville in a couple of weeks.
The reason for my question is that I am hoping someone has some suggestions that she can present to her docs to help her fine tune her meds plan so that she can have the type of race she deserves in Louisville…
Thanks in advance,
Paul
Paul-
I have exercise induced asthma that does get slightly exaggerated during high-allergy seasons. My doctor prescribed Advair 250/50 once a day and I only have to use my albuterol rarely on an as-needed basis. The Advair is a great preventative but I always carry an albuterol inhaler on my bike and in my tri top on the run just in case.
EIA is a very common condition in endurance athletes and for the most part can be regulated/prevented with proper medication.
I take 2 puffs of Ventolin (salbutamol) before any workout/race. During heavy pollen season I also take Flonase (fluticasone) nasal spray to keep my sinuses from draining nastiness…which can also affect breathing.
Previously a chlorine allergy used to really trigger EIA. I took Singulair with Ventolin which helped significantly.
Good luck to her.
I used to have it real bad as a kid, ever since I gave up dairy products I have not had 1 attack since. Chlorine is also hard on me as well and am lucky to swim in a salt water pool.
Dan and I had it pretty bad in the old days, and used more and more medications to help manage it. It just got worse and worse, until we finally moved to the desert climate. For me it was also the mold issue for the most part. THe only relief I got other than meds, was buying a couple of those ionic breeze air cleaners. One at my bed, the other next to the computer. They get much of the really tiny stuff that floats around the air and gets trapped deep into the lungs…It is tough, but if it gets worse, you just have to move. Ask her if she feels better when she visits other types of climates. I used to travel a lot back then, and looking back I can now tell that it would begin to clear fairly quickly in favorable climates, just didnt put it all together back then…
EIA is often a tentative diagnosis arrived at when they don’t find anything else.
Does this athlete continue to have trouble breathing during exercise since that first episode?
I found that my Drs (2 different ones) kept trying to push me toward a diagnosis of asthma and it took 3 months with blood clots hitting my lungs before they finally figured it out.
She spent 2 days in the hospital undergoing a number of tests to help determine the cause. She does, in fact, continue to have issues since the first episode regardless of her meds…and it is sporadic (yesterday she did 92 miles with no breathing issues at all) Sat was very windy (lots of dust and crap in the air) and Sun was not so much…
I am suggesting that she chart her “bad days” and list the pollen counts for those days as well as any other factors (places she visited that day and the day before, etc.) to see if there is a consistent environmental trigger…
Otherwise she is continuing to work with her docs to make sure this is fully addressed and she will NOT quit until she has it “controlled”…
Paul
It’s good to know that she’s had some good days. That rules out some things.
does she respond well immediately to Albuterol/Salbuterol? That would be a clear indicator of asthma.
And does she feel the typical symptoms of asthma? Tightness in the chest and wheezing?
And does her heart rate hold to it’s normal pattern for her? ie. same HR as before at slow pace efforts (Z2 stuff) as well as at rest?
Some studies have shown Singulair works for EIA. Its a once a day medication, yet the best EIA protection is in the first 4 to 8 hours. I always took it the AM and could ride great on the weekends, yet had breathing issues for hard evening club rides. Tried it in the evening, and I believe it helps. For long distance stuff like IM, I would stick with AM dosage. For the most part IM pace does not trigger it for me, its the intense harder efforts.
Besides Singulair I am also on Advair, Allegra, and Nasarel. Most times it will take a combination of medications, that will require adjustment from time to time. Keep her from getting down, she can beat this.
I’ve been dealing with this a lot the past couple of months. My pulmonologist put me back on Advair which has helped. My asthma is exacerbated by gastric reflux, so decreasing caffeine and a few dietary changes also helped. Tell her to keep going back to the doctor if one thing doesn’t work. Good luck to her. I know how frustrating it is.
clm
Albuterol isn’t a solution, its emergency prevention if you are having problems at that time.
I hadn’t had any problems for 2 years until this year. my doctor put me on symbicort twice a day and i haven’t had any problems since. It didn’t take long at all to start working so i would see if she can give that a try.
Thank you for posting this question! Not meant to hijack, but I am going through something similar right now. I sure hope that she is able to get this under control.
This past week, my Dr. prescribed a ventolin puffer and advised that I should only use if necessary and report back in a couple of weeks. I have no history of breathing problems up until about 3 weeks ago. I just don’t feel like I can get a full breath. The lungs have a ‘fullness/pressure’ similar to the feeling of a chest cold, but without any of the other cold-like symptoms. Breathing is manageable, but it just doesn’t feel natural/comfortable.
A couple of weeks ago, I did a half-IM and at about 3km into run portion of a half-IM, I pulled off to the side as I was having some issues as it relates to a chronic injury…but when I stopped, within a few seconds I couldn’t catch my breath - almost like hyperventilating. I ended up calling it a day shortly after. This is what prompted the visit to the Dr.
I’ve done some high-intensity sessions indoors without difficulty, but this past weekend I was doing my long ride and decided to make a detour to do a steep climb. I was working hard and breathing was heavy, but controlled. After cresting the hill, I had another episode of being unable to catch my breath and could feel a bit of panic set in. I didn’t have the puffer with me (hadn’t even thought about taking it), and within about a minute or so, the feeling subsided…but the same fullness/constriction (don’t know how else to describe it) remained. So, maybe the high mold counts, pollen, dust, etc…could be the culprits?
I’ve always been a bit leery about taking certain meds if I think it’s something I can work through without them. But at what point do you determine it’s ‘time’ to use a puffer? IM looms in a few weeks for me as well.
