Damaged ouzo pro question
I have a Reynolds Ouzo Pro fork that is carbon. One of the aluminum ends that inserts onto the axel was slightly bent. Can this piece be taken out and replaced, or is it integrated in the carbon? Could it be heated and bent?
Take a wrench and fix it…it is REALLY soft metal. If you are afraid, send it to me, I will fix it and dontate it to someone that will ride it. It should be safe, I unfortunatly had to do that with an Ouzo Pro of mine when the tip got bent in to the point that a wheel could not be installed, I just bent it back out…and did 3 IronmMan and a bunch of 1/2’s on it. Still ride that fork too.
