Cyclists Improve Pedalling Efficacy and Performance After Heavy Strength Training
If you can’t hold proper form that is also wasted energy right? Think of how much wattage is lost by an inefficient pedal stroke. By having the muscle support to back up a proper technique you will be more efficient. Also gym work doesn’t always mean getting heavier. Lots can be said for correcting in-balances.
Wait, is this 2008? or 2006? or 2004? or 2003?..
Shakes head. The more things change, the more they stay the same.
It must be even before Dan came up with Slowtwitch and was ahead of his time!
Cjathey…how would you measure cycling efficiency? Total mechanical energy produced at the crank divided by (total heat produced by the body + total mechanical energy produced at crank) ?
Just asking how you would define efficiency and then how would you even measure it (if you define it as I did, it would be hard to measure the kilojoules of heat produced in a given time frame, vs total kilojoules of mechanical work that would be easy to measure with a quarq or SRM)?
Dev
The key thing about anything; you spend time on training you’re going to get better. Obviously this has to be focused on the task but there’s no surprise to me that people trained, and then they improved.
In a 5 minute workout, type IIb muscle fibers are going to have a larger contribution to your efforts. As the workout level gets longer and the output levels are more determined by your aerobic capacity, these IIb fibers are more and more irrelevant. I doubt Rasmussen had much in the way of developed IIb fibers… But like I said earlier, I can see how strength training (gaining IIb fiber capacity) could help on a short effort. It just means absolutely zero to triathletes, probably not even to people specializing in the super-sprint distances. Even a 10 mile bike is still at least 20 minutes for even the fastest of us…
Well that’s not entirely true. I can see a fairly large benefit in building muscle to sprint the initial part of the swim, but otherwise it is inefficient. I think this is why several swimmers struggle to really run well. As jack mott has mentioned muscle is very heavy. Someone like Sara Mclarty, albeit an amazing swimmer really hasn’t done much in this sport the way she was hyped to. Yes she can win the swim, and then watch everyone catch and pass her, which in my mind is a very depressing way to race.
There are a number of studies that back this up for all endurance sports. The key is maximal strength training. if you do normal weight training or strength endurance work in the gym the its more of a waste of time. strength endurance is best done in the hills. Here is a link below that sums up a number of studies with the positives to max strength training for endurance athletes
http://www.charlespoliquin.com/ArticlesMultimedia/Articles/Article/806/Ten_Reasons_Why_Runners_Should_Include_Weight_Trai.aspx
http://www.charlespoliquin.com/...ude_Weight_Trai.aspx
That article is full of so many “facts” that are repudiated by research, it is hardly worth reading. “Strength training will boost your metabolism…” Wrong. At least his core suggestions in improving core strength and doing weights via high HR intervals and ~50% maximal weightlifting are vaguely reasonable. Lets go out and do squats.
How much?
Play a game called use the search bar.
No please, give an answer beyond the FD/PC BS. I’m especially curious because the study doesn’t use the term “efficiency”; it says efficacy. Those two words have different meanings. In any case, I don’t think that you actually mean efficiency, defined as mechanical work performed divided by the metabolic cost of that work; you are talking about efficiency as meaning a more even application of force around the pedal stroke.
There is at least one study that found that those with the most effective pedal stroke i.e. those who produce the most wattage, had the most uneven application of force around the pedal stroke.
This IS what I’ve been talking about.
Humor me and give me a search string that will reveal the answer to that question.
There have been studies that show that increased lean body mass does increase basal metabolic rate. The Katch-McArdle formula (and I believe one other) are considered valid by many. Granted, these are estimations, but they wouldn’t be considered valid unless LBM had been shown to be a factor in calculating BMR and RMR.
Time trial riders are taller, bigger guys because w/kg does not correlate well to performance on a flat or mostly flat course. Smaller riders are penalized, or larger riders have an advantage, take your pick, because w/cda matters; not w/kg.
Now if you want my pet theory, I think that taller riders have a better chord ratio in the aero position, but that’s a hunch and worth what you paid for it.
Yes there is a fair amount of studies to back up his claims. But that was just one point that he made of many though the article. The most important point in the article is that you improve performance by added max strength training into you work load. How it works is still a little unclear but it’s believed that it’s due to neurological changes. Basically it means that you can recuit more of the muscle you already have. Then you have to train that muscle to gain full benifits. You go backwards to go forwards. You also get different hormonal responses to strength training to endurance training which can help performces in the long run.
Even Rasmussen held proper form, and he was a concentration camp victim.
On Rasmussen he actually did a large amount of on bike strength training. I was lucky enough to train with him for a day a few years back. He would be at his heaviest (64-66kg) around march/April after he finished his strength block then slowly cut down to lose all the extra non functional muscle.
Someone here, either Andy Coggan or Tom A did an N=1 study on themselves where they did weight training, and while their lift numbers improved steadily it did not affect their FTP
It didn’t in this study either. All this study says is that “negative torque” zone was made smaller, and the power improved in a 5min max effort… compared to cyclists who were doing nothing but endurance training!
1st point… negative torque on the upstroke has not been shown to reduce power output. So why should we be worried about it?
2nd point… the guys doing nothing but endurance riding were obviously not training to produce a peak performance at anything… so are a really poor baseline. I suppose if the weight training guys had performed worse that would have been useful info, but performing better, means basically nothing.
3rd point… all of these studies kinda piss me off, because they provide no useful info. Useful info would be taking a well trained group of cyclists and switching their complete training plan from A to B… with the important result being, did they or did they not improve their peak performance in their goal event? For instance regarding this study, we need to know if the cyclists who did the weight training went on to achieve PRs, compared to ones who didn’t do weight training.
Please don’t think I’m trolling (or abusing you the OP).
Questions that I see needing answers in the full article:
1.) Is the control effective? Control is doing the same thing per usual, test group ADDED heavy lifting regime–what are the effects of said extra efforts? Is said regime at all optimal?
2.) Definition of “efficiency”? Are they discussing metabolic cost to joules to the road or are they defining it in some other fashion?
Of course I’m interested in the testing regime’s specifics as well. We’ll see!
Agreed.
The Coyle paper you refer to–I looked at the crank angle force graphs; (and while I didn’t rip them out of the paper and really analyze) it seemed like the power to the road was actually quite even at all crank angles. I.e. the summed torque of both legs on the crank at any crank angle was pretty even, or at least more consistent than the untrained cyclists. The professionals were just far more push-centric.
Stability muscles? That’s about all I can think would be improved with that.
if stability muscles were so important, how does one ride or run without first increasing their stability strength to support them in their activity?
Dude, seriously, do some reading or something.
