anyone used this trainer? curious to the ability to do sim climbs, etc as compared to typical magnetic trainers and fluid trainers.
I have owned a Magneto trainer since the fall of 2004. It is and was the smoothest magnet based resistance training that I have used. The progressive resistance unit is great, no need to have a pain in the wire mount to adjust resistance. In addition, I love the Cycle Ops mounting system, the best of any trainer unit on the market. The cons about the Magneto trainer is that it while smoother and quieter than a standard mag trainer, it is not as smooth as either the Cycle Ops Fluid 2, the Kurt Kinetic fluid trainer or any of the Elite (brand) of fluid trainers. Furthermore, the resistance provided by the Magneto is substantially harder gear for gear than other Cycle Ops Fluid 2 and Elite fluid trainers. I have found that a 50/15 combination on an Elite fluid unit is roughly equal to a 50/17 or 18 on my Magneto.
On the whole I give the Magneto an 8/10. Big points for the easy mounting system, relatively quiet noise level and progressive resistence unit (no wires). Cons are the aluminum roller (tire slips more easily than an Elite type elastogel roller) and the less smooth resistence unit. The extra resistance provided can easily be countered by a larger cassette.
With that said, if I had to do it again, I would buy the Elite Primo or the Cycle Ops Fluid 2.
thanks for the info. so you are saying that in a 53/13-15 would be a tough sim climb with cadence around 60-70? that’s what i’m looking for. for easy stuff, can you spin easy in a 39/18-19?
Reply to: With that said, if I had to do it again, I would buy the Elite Primo or the Cycle Ops Fluid 2.
What don’t you like about the Kurt Kinetic fluid trainer? A friend of mine is looking at all three for an after xmas present.(for her self)
The Kurt Kinetic is great, but the mounting system isn’t as nice as the Cycle Ops models nor are any other trainer models. Finally, Kurt Kinetic are really expensive and not worth the extra money paid when compared to a Fluid 2 or Primo Fluid trainer in my opinion.
Thanks!
Merry Christmas
but the KK is supposed to be leak proof, whereas i have heard several stories of the fluid2 leaking. this is why i have shyed away from fluids all these years; that and the ability to really crank up the resistance on a mag. the most intriguing option to me is the 1up trainer, with the ability to add resistance with the extra balls. have you seen the resistance curves on those, insane.
You must have legs stronger than Alessandro Petachhi if their isn’t enough resistence from the Elite Primo Fluid or Cycle Ops Fluid 2;) It’s funny how the fluid leaking story seems to persist, but no one ever seems to have had either the Cycle Ops Fluid 2 or Elite Primo trainers actually having leaking problems. Personnally, I know the original early model fluid trainers had some leakage problems that were fixed and the new models mentioned don’t ever have leakage problems unless the fluid units are/were damaged.
