Trying to map Road coordinates over to my CX bike. Yes, going back next week for an official fit but I’m kind of impatient and want to ride the CX bike. Back feels (and is) rounded. Low back feels the stress and not so bad during the ride but pretty pissed off afterwards. Saddle to handlebar drop is almost identical to Road setup.
I keep my CX fit pretty similar to my road bike, but I bring the h-bars up a little higher and in a little closer for better handling off-road. Are you using it to race CX (40-60min) or for long multi-hour gravel grinder rides?
CX bike fit depends on how you are actually going to use the bike. (Road, Gravel, CX Racing, etc.?)
In general, start with road dimensions, then move to a *slightly *more upright position if you’re planning to race CX. Similarly, you might adjust the handlebar reach 5-10mm closer for CX (you’ll spend most of the time on the hoods). These adjustments can be easily made via shorter/higher stem position or a *minor *upward-rotation of handlebar (bringing hoods higher and closer, etc.).
What to look at first? Saddle height? Fore/aft?
Sorry, don’t have a photo handy.
If you are racing, read and digest what Fredly wrote.
Personally, my cx position from my road position ends up being about 4cm higher, 1cm closer, my handlebar angle is the same, but my levers are much higher up on my bar such that my wrists are not bent either direction. My fore/aft is the same after factoring in having my cleats a little further back compared to my road shoes. My saddle height is about 2-3mm lower to account for bumpy pedalling.
