Cutting steerer tube
Well, I’ve finally decided to cut my steerer tube down, but I can’t decide how much of it I want to leave above the stem. Would you suggest that maybe I leave enough above the stem so that I can fit 1.5 cm of spacers just in case I wind up with cutter’s remorse at some point down the line? 1 cm?
I say if you’re gonna cut it…then cut it.
Get in your zone, know that’s where it feels right, leave nothing to spare.
(measure twice though)
Mike,
I had the same questions before i cut mine all the way down. Leave it alone until you are can ride in aero comfortably and are not concerned about it. If and when you get to that point then cut it all the way! Why would you ever go back?
I’ve been comfortably riding with no spacers below (and 6 cm above) the stem for quite a while. I’m finally getting around to cutting the steerer so that I don’t impale myself on it.
