I need to cut down a carbon fiber seatpost (Cervelo). I’ve been told it’s tricky and can release dangerous vapors. So, how is it done correctly? What special tools, if any? What precautions?
Thanks,
Thanks,
dust mask
paper on cutting line
dremel
dangerous vapours (tiny fibers) is from kevlar that is dangerous suspion causing cancer
Hacksaw with a blade that has 32 tpi. That’s what is recommended by Reynolds. Don’t forget your eye protection and mask.
Wrapping the area you want to cut will help reduce any splintering caused by cutting the carbon too. In addition you can draw a nice line to make sure you make a straight cut.
A bandsaw will do a good job, so will a hacksaw. Either should have a fine blade (like 14tpi on the bandsaw, 20 with a hacksaw). Definetely use a mask and put masking tape around the post before you start cutting. -Andy
As was mentioned, a fine toothed hacksaw is a must, for an inexperienced person I would not recommend a dremel (power tools make quick mistakes)
wrap the area to be cut in masking tape, it allows you to draw an easy to follow line and helps prevent the saw slipping.
one the cut is made, sand the edges of the cut to smooth off any rough fibres which will appear during the cutting process.
The dust mask is a good idea, I don’t know if carbon dust is hazardous, but no one thought asbestos was either.
When I did this, I followed the instructions provided by parktool. Half way down the page, there’s a section labeled “NOTE FOR CARBON FIBER:”
I’m pretty sure that carbon dust is a carcinogen. Sawdust is too though.
