sac wrote: OK, I was just testing your faith
Did I pass?
Like I’ve said before, PC’s may only help people with screwed up pedal strokes…like me. However, maybe they can also help people with darn good pedal strokes…I’ll have to leave that call up to those with darn good pedal strokes to begin with!
I am curious what a spin-scan would look like with Rotor Cranks…i.e., do Rotors result in a higher valley, a higher peak, or both? (Or neither?) If it’s a higher valley, then the idea that they lessen the “dead spot” would be correct in how they work. But, if the valley stays the same and the peak is higher…or the area under the peak is greater, then THAT would be how they work. Maybe they do both. Of course, it may depend upon each individual rider’s pedal stroke.
As far as PC’s on a computrainer: I find that no matter how much I train on PC’s, after a while, it is apparent that the rising pedal is slightly slower to the top…I know this because the “peg” on the large chainring gradually moves further and further in front of the right crankarm…that means I’m slow getting to the top. (I’m assuming the same is true on the left, there just isn’t a marker that I can see to tell.) So, using PC’s on a computrainer might show that the area under the curve is slightly greater in my stroke, which would go along with what I see on the road…as long as my position is similar on a PC bike and a regular-crankset bike, my speed is slightly faster on the PC bike…as long as I’m pedalling…and THOSE two things are the key: Same position, continuous pedalling.
I have not worked on adaptation with PC’s in the aero position. I have adapted pretty well on PC’s, but, I still have to rest a little every 15-20 minutes. After about 1-1.5 hours, my hip flexors are getting toasted, and I have to rest them more and more often. So, I’m certainly not a poster-boy for optimal PC training. One big reason is that my neck pain/numbness is aggravated by riding on my road bike, and that’s the bike my PC’s are on. Lucky for me, I can ride in the aero position for much longer before my neck pain makes me stop, so I can do longer triathlons…but, it limits the length of my PC rides.
This computrainer stuff might provide some decent information if someone had access to the different cranks, and had trained on PC’s enough to become somewhat adapted.
