Ct help
Why when I start riding do all the numbers get unreadable? at first they are good
Do you mean the graphics on the computer monitor get all screwed up? Are you running 3D or just spincscan? You could be simply bumping up against your machine’s graphics limits. Check your memory, CPU speed, etc. against the specs.
On the 3D, I reduced the number of data points showing at the bottom. The options dialogue box will let you limit what is showing. That might help. I don’t use the 3D anymore, but I think I only had time and watts showing.
Even with the spinscan only display (which requires almost no graphics power), I sometimes had the display go hoohey on me. I would re-boot, re-check all the plugs and try again.
Hope this helps. Good luck. I’m headed out to the garage in a few minutes to do a ride.
Everything works except when I start riding the guy goes for a while and then stops. And the data numbers just get jumbled.
