CT calibration
Can someone help this CT neophyte out please? When I calibrate my CT - I cannot get the load above .8. I have the correct tire pressure and also the resistance on the tire is as per the book. The load generator was replaced last year but still cannot get it to the suggested 2.0. Any Ideas
Thanks
are you sure you are tightening the roller enough? give it another crank or two and see if your calibrarion number goes up - it ought to.
Don’t know what the book says, but you gotta tighten it. Turn it several turns, hop on, recalibrate, repeat until 2.0.
2.0 isn’t suggested. it’s just a default number. read the manual carefully. it says base the resistance on the kind of course you’ll be riding. less resistance for a flat course and more for a hilly one without any tire slippage. (i’m paraphrasing). that said, .8 is way to little. crank the knob.
Huh?
I thought after warming up for 5 minutes you pressed the - and + keys on the handlebar controller simultaneously (need to unplug “stereo” cable), then you bring the speed up to 25 mph and then just “stop”. You then get a reading on the display of the handlebar controller. Do this three times to see how consistent the reading is. Mine were something like 285, 265 and 265. I think the last step is you press one of the “F” keys (F1, F2 oe F3).
Do I have a different set up?
when did you buy your ct? sounds like you’re getting wattage numbers not calibration numbers.
Could you please tell me where in the manual you see these instructions to calibrate?
Thanks!
He’s more likely just not seeing the decimal…
I bought from racermate directly. Please see my other post. What page in what manual did you see for instructions on calibration?
thx
Whew!
I think you’re right - probably missing a decimal.
I used the procedure outlined in http://www.computrainer.com/html/manuals/CTBasicmanual.pdf page 15
Feman,
I apologize for hijacking your post.
ON Page 8 of my manual printed in 12/99 I has the three steps to calibrate the CT. I have been doing this and still cannot get the reading in lbs above .8. But on the advice of others will really crank down the PRess on force and see if that makes a difference. Thanks
That was correct this morning - after advice here I cranked down on the pressure and re calibrated and got 1.58. I think this is where I need to be. ???Thanks
Thanks I am on the bike again tomorrow so will crank it even more.
I was always under the impression that you performed the calibration so that no matter how you set up the equipment the uploading of the calibration number would compensate? For example if you put it on real loose and got 1.14 and then uploaded it, the CT would take care of the rest (ie beef it up)?
Are you supposed to be playing around with the setup, ie undertaking several calibrations, until you get it close enough to 2.00 and the upload the info?
Cheers
Mike
Mike
2.0 is not the “right” number - it is just a default that RM choose (they say this themselves in the manual).
As long as (i) you calibrate the CT unit correctly to compensate for the lower press on force; and (ii) you are not getting any tire slippage, you can go with levels below 2.0.
I find that that I am using 1.5-1.75 on flattish courses and around 2 on courses with reasonable gradients.
Ok so what you’re all saying is that in order to avoid any slippage on hilly courses you tighten the knob such that the resultant calibration number turns out to be around 1.5 to 2?
And if by some miracle I found that I got no slippage on the chosen course when the calibration number was reading 1.14 then the wattages produced are still accurate (to the CT’s ability anyway)?
Mike
D
Yes, that is my understanding.
