A little about me: 26 y/o male with a decent base of several years (5’9, 140 lbs). I will race only sprint and Oly in 2007 with maybe a half thrown in for fun, but I won’t train specifically for it. I was plagued with some injuries on 06 some I’m trying to build up my miles over the winter and increase my base. Currently I’m running about 20 miles per week spread across 4 runs. I’m looking to get up to about 30 miles per week by March, but I’ve definately been obeying all the 10% rules. Here’s my current run plan:
Tuesday: “long” run of about 7.5-8 miles at marathon pace
Thursday: 20-30 min tempo run of about 5-6 miles
Saturday: 4-5 mile easy run
Sunday: 3-4 mile easy run or brick workout
My main questions:
How should I best increase my mileage safely? Should I increase the length of each run or increase frequency?
Do you think it’s safe to increase miles per week by lengthening the long run?
Are there any key workouts I’m missing for base building? I should add that I substitute one of the weekend runs for a track workout every other week or so.
I think that you can almost throw the 10% rule out the window…many will disagree. Since you are already running 20-25 miles a week, you could easily get to 30 in a week or two. I like to increase frequency up to 5 days of running per week and then add first to the long run and second to another weekly run.
See above.
I like to do some strides year round. 100m - 200m repeats near mile pace with long recoveries. Tempo work is good, hills are good. I generally save true brick workouts for the 8 or so weeks leading into a race. I might to an easier or moderate transition run every couple of weeks though.
**Run duration isn’t a key metric. Simply run 45-60 minutes each time, follow the cap, make sure that you have at least one day per week without any lower body work. For advanced athletes, after you’ve done 3-4 weeks of this protocol, you could add a second run on one day; or a long hike instead of your run – keep the rest day! After 6-8 weeks you can add a longer run. However, the greatest gains come from volume built through frequency – not longer or faster runs.
From a first look I would say you are not running enough. You are running 20-30min at pace per week. No where near enough to get better. If you add up all the max miles you get 23 miles per week. I am not saying that you need to do 70+ per week but 23 is too few. I would make my long runs more like 10+. Easy runs more 5-8 depending on how much you think you can handle. I would also add a day of hills every week. hills are a way of doing a speed workout without knowing it.
It appears you are pretty light and in shape (140 5’9") so you should be able to handle more than your current plan. Jumping from 20 to 30 should not be an issue.
I would incrementally increase the long run up to half marathon distance by dropping the pace to aerobic pace. Since you are base building, drop the every other weekend track stuff. Increase the Saturday mileage slightly and run these runs at MP. One week increase the LSD runs, next week increase the Sat MP runs. Don’t change the other two. You are almost there.
What is your marathon pace? Why is marathon pace an important pace if you’re not going to race at that pace?
How does your MP relate to your tempo run pace? To your easy run pace?
Your 8 mile run, while it is your longest run, isn’t necessarily a long run in the sense that it’s getting you to the 1 1/2 hr. mark. But that’s a guess, I don’t know how fast you’re running.
Do you do strides regularly?
If the goal is to hammer on the run after riding hard for an hour on the bike, how is your training addressing that?
Forget doing any speedwork until you are running a signifcant number of miles (and even then only use it before your A-race). I ran intervals twice a week when I was running 20-25 mpw and still ran slow in O-distance 10Ks. I dropped a couple of minutes in the 10K when I averaged 40-45 a week for a while, with no speed work. Read the article on the front ST page where Dan interviewed the guy who ran a 1:58 800 at age 55 or so. He never trains at race pace for 800. An O-distance race is 10 times longer, so you really need to be aerobically efficient and that comes from lots of aerobic training.
Chad
You’re definately on the right track…I’m not running near enough to get better, however given my circumstances I’m running as much as I can right now. Last year I had a stress fracture in my foot which kept me off my feet for 3 months and the rest of the year I averaged a measly 7 miles per week due to the fracture and hip problems. However, I still improved overall and set a 5k pr in the fall (17:30) and a 5 mile pr (30:30). Right now I’m so paranoid about re-injury that it’s much better to be on the safe side rather than risk another setback. Believe me, getting injured was the pits and I’d rather be healthy and slower than risk an injury trying to shave off a few seconds. Jumping from 20-30 for the average 140 pounder shouldn’t be an issue but I consider myself fragile goods : )
When I said marathon pace, I meant “easy” pace, as determined by the Jack Daniels book. My easy pace which I do my long runs at is about 7-7:15 per mile. I guess I do this run at this pace because Daniels more or less says to. My long run takes about 54-60 min depending on how I feel (I’m aiming to get this up to about an hour and a half). My tempo run is done at about 6:05 per mile. I don’t really do strides right now, however I go through phases where I do them regularly. To answer your question about how my training addresses hammering the run after an hour on the bike, Sundays are usually dedicated to an hour to two on the trainer (hard) followed by 30-40 minutes fairly easy running. As Spring rolls around, I’ll pick up the pace on the run portion of this brick.
If you can do a tempo run at 6:05 your MP is probably quite a bit faster than 7:15. Your Jack Daniels MP, as he defines it, would be probably around 6:15 to 6:20.
If you think that 7:15 would be your Marathon Pace if you raced a marathon then Endurance is probably a limiter and you should address that.
Also, I think that if you can run a 6:05 tempo run and your long run is about an hour, well…you’re just not doing a long run. I’m not saying you have to. I’m just sayin’.
Keep in mind that its not always total miles that will cause injury. It’s total stress. So you can’t fool your body into getting into better shape without injury by shaving off miles here but then adding intensity there (I have created this problem for myself very recently).
So, in that regard, your first goal is to increase your mileage. John Kellog recommends 50% of your running to be done on soft surfaces. This includes grass, gravel paths, and trails. You may or may not want to do some running on a treadmill with a small incline. This will reduce some pounding, yet, it puts ALL of the pounding in exactly the same place on each and every step. For some that reduces your chance of injury, for others it increases it. Aqua jogging is also another great suppliment (and it really does work!).
Personaly, I think you should drop ALL intensity until you reach at least 30 miles a week. Once you are there I’d then add in one 20 minute tempo run a week. The first REAL intense workouts could be done on hills. This will help reduce your risk of injury. They tend to be easier on the legs while building yourself up for harder workouts to come. After that you can move on to some track work, though it should be low volume with lots of rest…again, building up your body’s tolerance of the hard workouts.
Yes, you can increase weekly mileage by increasing your long run, but I’d also increas your other runs as well. Your ultimate goal for a long run is 90+ minutes. BTW, your long run should not be at “Marathon Pace.” It should be at ~ 1 to 2 minutes slower than your tempo run pace.
Frquency will help you increase your mileage easier. It’s all a balancing act, though. You won’t get as much by adding a 1-2 mile run in the week as you will by increasing your Saturday run to 7-8 miles, but it will be easier. Runs of 2 miles or less are fine as long as the goal is to increase them to 3-4 miles eventualy.
What is your ultimate goal? This is all fine and dandy until you tell me that you plan to race your ass off for 6 months straight. ; )
