Critique my position (pics and video)
Been working on my position on my Plasma. Since my last post I`ve:
-lowered the seat 1,5cm.
-put the T2 aerobars under the base bar, and fittet the armrests with a rise kit
-put the seat almost 2cm back
-put the aerobars as close to eachother as possible.
Still not 100% happy. I think the seat stil is a bit high (seriously:) Should i stretch more out? And if yes, should i do this by extending the aerobars (and keep the amrests where they are) or extend the stem? Maybe I can get lower with a descending stem?
What do u think?
Video here: http://www.youtube.com/watch?v=9lW8gCuAYtw
http://bilder.vgb.no/10299/img_45c7896d87122.jpg
http://bilder.vgb.no/10299/img_45c788d5a3666.jpg
Seat looks high to me on static image and when I froze the video image.
Is that where you naturally sit on the saddle? Wow. The rear of my saddle disappears on my position pic.
I have nothing useful to say about your position but that is the best attempt yet to avoid irrelevant posts about your background / home decorating.
Which I suppose makes my post kind of ironic but there you go…
Front view looks pretty good if you ask me. Some will honestly feel the seat is too high, but that is about the way I ride mine and feel comfortable doing it. You look comfortable to me, as I ride with a short cockpit as well. I think you could easily lengthen the stem by a centimeter or two but if you are comfy where you are, I’d stick. Is there any way you can get your helmet to get closer to your back? There is quite a gap there. Overall I think it’s pretty good.
:slight_smile:
Actually thought of that:) And redecorating the livingroom and kitchen at the moment fitted perfect with taking these pics:
Here is a pic taken the oposite way…hehe…would have made a great background!
http://bilder.vgb.no/10299/img_45b1f07fde682.jpg
Great “Scott”!!!
I can’t put my finger on it, but your pedal stroke looks real professional. It’s like watching a race on TV or something. On the other hand…Your head is way the hell up there. It looks like it constitutes about a 3rd of your overall frontal area.
If your head’s going to be that high, you may as well ride in a road position where your shoulders are up too. You’ll get more power that way and your drag won’t be any worse for it. I know I sound like a broken record, but DROP THAT HEAD!!
Incidentally, when I watched your video, I saw a link to this one:
http://www.youtube.com/watch?v=lWAkeQFPTpk&mode=related&search=
I have no idea who this guy is, but his position (other than the seat which is a little too high) is very good. It should give you a better sense of how to position your head and torso.
– jens
That other guy does look quite excellent, though I haven’t seen that position posted on BTR or anywhere else that I frequent.
Espen on the other hand, needs to be pushing some serious watts to be fast with his current ‘head in the wind’ situation.
I’d recommend:
Seat down a pretty significant amount. 1-1.5cm more.
Flatter or negative rise stem; Ritchey 4-axis in -17 gets most frames pretty flat. You may need even more than that because of the length of your arms.
Chris
Just my .02—I’m not into giving out this kind of advice so take it FWIW
You seem really forward on your saddle-- why not just move it forward a bit so you’ll be more comfortable at longer distances?
Your elbows seem pretty narrow. My understanding is that they should deflect the wind around your knees—yours are so tight the wind is going to hit your knees a bit.
Your helmet tail should be more flush with your back otherwise you’re negating some of the fairing benefit.----just my understanding.
His front wheel is on the ground, so he’s higher up than that picture would indicate. I think the video shows no riser for the front.
No expert here, but it looks like your front wheel is on the ground, which puts you even higher than it would appear. Is that correct? Are the axles level?
No expert here, but you looked scrunched. I think you need a longer stem???
FWIW, lots of TTists and triathletes appear to ride way out on the nose.
No its not on the ground, same hight as back weel. Just cut the book out, to avoid questions on which book etc;-)
Try a longer stem, Drop the front end and maybe put your bars a little further apart to improve breathing. On your youtube page I liked your position on the P3 much better
From the photo I measured your knee angle at 162°
Drop that seat a lot more (maybe 2 cm) sit on the seat correctly (not on the tip) and repost a photo so I can measure it again.
jaretj
I think that guy on the video has is saddle too high, just look at his feet. But it stills a very good position, i guess. Specialy his head and arms.
How tall is Cameron Brown? In cm please?
Hes on the same bike and size (S) as me, and his back is much flatter than mine. And it even looks like hes got spacers on the bike and the aerobars mounted on topp of his aerobars.
Custom made frame?
http://www.digitaltriathlon.com/admin/resources/images/9060.jpg
well my comment try to reach you ankle the center of the pedal this with out shoes if you can do that then the sadle hiegt is ok but it seems to high for me ,also becuase you upper body moves
and onather advise buy another helmet that leaves abou5 0.5 cm btween helmet and body
My take is that you shouldn’t be asking us…
You should be talking to your fit gal/guy!
Don’t have a fit gal/guy? Go GET ONE!!! Seriously, - my fit cost over $350 and more with the parts and took nearly 6 hours. He spent an hour and 1/2 on my feet. My opinion: it’s better to buy a $2500 bike that fits well and spend $500 on a pro fit, - SOMEONE OTHER THAN THE PERSON WHO SOLD YOU THE BIKE, - than $4K plus on a bike that you risk…
Second, - being more AERO does you ZERO good if being more AERO is so uncomfortable that you’re shifting in and out of position…
My question to you is, - are you comfortable in that position?
Well…the bike is sponsored.
Norway is a small tri-country. Not to many fit-guys around that knows about IM racing. Thats why I`m using ST.
I dont fell 100% comfortabel. Not yet anyway. But I have not trained a lot in it yet either. We have -10 celicius here now, and I will not get it out until mid march anyway. So until then I am on the trainer 1-2times a week, doing LT intervals. But getting help here for sure will make it easier to find the prfekt position - and then I can do just small adjustments when I get it out.
Capice??
I’m sorry,…
I didn’t fully understand your situation.
Apologies. It is still my experience that you should sneak a chance to visit a good, independent fit person who has no stake in selling you stuff, - but one whom you pay exclusively for that job.
And,… be comfortable. Staying aero comfortably is more important than staying aero uncomfortably.
Speaking for myself, - I am less aero because i raised up my aerobars about 3 centimeters. But now, - I am far more comfortable, and me and my bike are far less twitchy. I have more control over the bike at speed, and am far more comfortable, - so I want to stay in the aerobars longer. Remaining locked in a semi aero position over a long time, is better than getting in and out of aero position because you’re uncomfortable, or to pass, or because of turns or road conditions…
