First side on race shot I’ve gotten on the new bike. P3C has different geometry than my p3SL did, plus different aerobars now.
Looks like maybe I need to rotate the extensions up a weee bit, my forearms look down angled. for shame. maybe could hold my head lower too, something to experiment with.
this is a half iron setup here. no integrated hydration
172.5 on the crankarms.
The extensions are probably a wee bit shorter than I would like ideally, but I think the next size up will be a wee bit too long. what to do! It was comfy for all 3.25 hours of savageman so I think I’ll just keep em.
I think you probably already have the changes you need to make. Really just getting your hands higher (forearms level) and turtling your head more. Also, it looks like you could shrug your shoulders in narrower. Hard to tell without a shot from the front.
How have you not broken the hour yet with all that aero?
Looks absolutely great Jack. You can split hairs and bring up the hands.
If you can get the head lower that’s good too, if you just look down the tail will be off your back. lowering the head and raising the tail is probably a net improvement I suppose.
I would not change anything based on this pic. Any appearance of off angles could have more to do w/camera-to-subject angle than anything else. Looks close enough to level to me…if that’s what you’re going for. A change in hand position will affect your drag as much or more than any change in the bar mount angle. That’s a damn good position. There are no obvious changes to be made. Well…maybe your head position, but getting that lower out of the wind might not be sustainable over longer tri distances. Get thee to a wind tunnel or do some testing via RChung’s methods if you think there is room to improve. Frankly, I’d advise JFT.
